http://auszookers.com/forum/
Removing Axles? (Bent diff) Suzuki Jimny
http://auszookers.com/forum/viewtopic.php?f=5&t=41018
Author:  JuniorJoel [ Tue May 21, 2013 9:22 am ]
Post subject:  Removing Axles? (Bent diff) Suzuki Jimny
Hi guys,
Basically, I Bent the front diff on my suzuki Jimny and am fixing it at the moment.
I have stripped everything of the old diff bar the diff center and old axles.
But, i cant remove the old axles :/ They are bent and it means that what ever i do i cant pull them out. This is a problem because it is stopping me from getting the diff center out which is all i need to finish of my new diff.
Does anyone know a way of doing this? Method?
All help is much appreciated
Thanks
Author:  alien [ Tue May 21, 2013 9:34 am ]
Post subject:  Re: Removing Axles? (Bent diff) Suzuki Jimny
angle grinder to cut the diff tube in half? =)
Author:  tanshi [ Tue May 21, 2013 9:34 am ]
what are you doing with the old diff housing?
if your throwing it put a grinder through the axle tubes to free off the pressure.
Author:  chris77 [ Tue May 21, 2013 1:13 pm ]
What way is it bent ? have you taken all the diff head fasteners out ? That may give you enough wriggle room to get the axle out by leavering up one side to releave the other etc , won't take much . Otherwise its cut the diff housing tubes as the guys have said .
I recently had to use sledge hammer and crow bars to get a hilux center out as not only were both tubes bent but the diff head face and housing area was bent and pinching the head so it would not come out . ( was a modified head so had a bit less clearance than standard :) )
