| SV620 vitara services manual http://auszookers.com/forum/viewtopic.php?f=5&t=41047 |
| Author: | Chairman [ Wed May 22, 2013 7:15 pm ] |
| Post subject: | SV620 vitara services manual |
Can any one post a link or send me in the right direction for a services manual for the SV620 Vitara. I'm leaking oil from the engine which i suspect its coming from the sump seal, need to gather as much information on Engine pan removal before i tackle it, as i'm unsure whether or not its a gasket seal or simply use the handy blue gasket glue. |
| Author: | atari4x4 [ Wed May 22, 2013 7:37 pm ] |
| Post subject: | Re: SV620 vitara services manual |
my guess is rear main or front crank seal... where is it leaking from? |
| Author: | DarkHorse [ Wed May 22, 2013 8:31 pm ] |
Wot ee sed - usually one of the main crank seals is the culprit. Easy to eliminate the sump - run your hand around the block just above where the pan bolts up and if your fingers get slippery it's coming from higher up. |
| Author: | Rhinoman [ Wed May 22, 2013 8:54 pm ] |
I've got one, I'll sort out a link later, the current one seems to be broken: http://www.rhinoman.org |
| Author: | Rhinoman [ Thu May 23, 2013 7:15 am ] |
The SV620 supplements are here: http://www.rhinoman.org/manuals/Vitara/SV620.zip |
