| Jimny transfer case brackets. http://auszookers.com/forum/viewtopic.php?f=5&t=41137 |
| Author: | reddragon [ Wed May 29, 2013 3:39 pm ] |
| Post subject: | Jimny transfer case brackets. |
Just wondering if many people have broken the factory jimny transfer case brackets. Was reading on the off road armoury website that they are "the most likely thing to break on your Jimny as soon as you starts driving hard". Was wondering if this is true or if they are just trying to sell more crap. Thanks |
| Author: | jimny_timmy [ Wed May 29, 2013 5:52 pm ] |
| Post subject: | Re: Jimny Trans Case Brackets |
Very very very true Their mounts are awesome |
| Author: | Mike57 [ Wed May 29, 2013 6:08 pm ] |
Well I can say that I stretched my chain before breaking the transfer mounting brackets. The stock rubber mounts have a lot of stretch in them and I think that protects the brackets somewhat. If you had more rigid mounts I wonder if that might put more stress on the brackets? |
| Author: | jimny_timmy [ Wed May 29, 2013 6:34 pm ] |
Mike57 wrote: Well I can say that I stretched my chain before breaking the transfer mounting brackets. The stock rubber mounts have a lot of stretch in them and I think that protects the brackets somewhat. If you had more rigid mounts I wonder if that might put more stress on the brackets? I bumped my transfer on a sand dune and snapped the bracket clean in half... They're only cast alloy and weak as shit
| Author: | reddragon [ Wed May 29, 2013 7:58 pm ] |
Holy crap, that's sux jimny timmy. Ima gonna order a bunch of stuff for ORA soon, ill add them to the order. Thanks |
| Author: | jimny_timmy [ Wed May 29, 2013 8:02 pm ] |
What model jimny do you have? |
| Author: | Mike57 [ Wed May 29, 2013 10:30 pm ] |
Ok I see how that might happen. I have the MIC offroad compact bash plate on my transfer case. That prevents the transfer case from taking any knocks and has its own mounting brackets that more or less reinforce the original alloy ones. I thought you were saying that the original brackets would break from the torque placed on them from the drive train. If you had any sort of bash plate would that not stop the transfer case from taking any knocks? Mike |
| Author: | Bugsta [ Wed May 29, 2013 11:25 pm ] |
Broke mine within a month of new and with minimal use. Now have custom steel brackets with Urethane mounts. No case issues since, except for slipping chain just this year. |
| Author: | reddragon [ Thu May 30, 2013 4:04 pm ] |
jimny_timmy wrote: What model jimny do you have? Its a 2011 model |
| Author: | jimny_timmy [ Thu May 30, 2013 9:20 pm ] |
Fair enough. You could also consider the sierra case swap at the same time, but you will need to replace your gearbox too. Just some food for thought before you buy those brackets and then maybe have to change them later on. |
| Author: | 11acb [ Sun Jun 15, 2014 6:57 pm ] |
| Post subject: | Re: Jimny transfer case brackets. |
broke mine today in the exact same spot as jimnytimmy |
