It is currently Sat Oct 03, 2026 2:22 pm
Post Posted: Thu Feb 19, 2009 10:32 pm
hay dose any one no if you can replace the bush in the front struts? one of mine is flogged out and the local mechanic seems to think i have to buy new struts cos you cant replace them, thay are the ultimate struts and king springs set thats on ebay for sale all the time.
its an old pic but thats the bush at the bottom that needs replacing
cheers scott
black coily, 30 inch tyers, 2 inch suspention, 2 i
Post Posted: Thu Feb 19, 2009 11:44 pm
If I had one I could make a mould and make you as many as you liked. I assume we are looking at the shock bush. You should be able to get them anywhere really. I have a few different shock moulds. Sure one of them should fit. Just be a std cotton reel type.
Post Posted: Fri Feb 20, 2009 12:16 am
10 bucks its the same as tj wrangler bottoms or vitara rear bottom! its not a bonded bush so it can be removed. it just has a steel sleeve in it. try vit rear bottoms from ripco etc :wink:
Post Posted: Fri Feb 20, 2009 2:19 am
thanks guys, so the vit rear bottom bushes will fit joe ?
cheers scott
Users browsing this forum: No registered users and 185 guests
