It is currently Thu Sep 24, 2026 7:17 am
Vehicle: vitara
Post Posted: Fri May 31, 2013 10:07 am
just phone to order my kit and bloje says its only 30mm lift kit as 2" isnt listed for a swb 1995 vitara. l
do I order it or not? am I getting ripped off again?
is it really that hard to get 2" lift kit for a vitara by Wednesday for less then $1000?
I dont wanna order it to find out I made a mistake. cant afford to
any advise please?
Post Posted: Fri May 31, 2013 12:27 pm
If you still have original suspension in your most likely to have sagged lower suspension to begin with. Most find that combined with new springs can result in bigger than 2" lift. Alot of the manufacturers won't state 2" definite lift because there are alot of different factors to change final ride height.
Vehicle: vitara
Post Posted: Fri May 31, 2013 12:32 pm
thank you chop. after doing a little research ive desided to go with dobinson lift kit. 40mm and im getting
grand vitara front springs. plus camba adjustment bolts for less than $1k
should be here tuesday/Wednesday
Post Posted: Fri May 31, 2013 1:37 pm
Then order a kit to suit a 5 door.
Vehicle: vitara
Post Posted: Fri May 31, 2013 2:41 pm
will the 5 door kit go on a 2door?
Post Posted: Fri May 31, 2013 2:43 pm
yeah.
Vehicle: vitara
Post Posted: Fri May 31, 2013 2:45 pm
kool thanks
Users browsing this forum: No registered users and 193 guests
