Got a few more dramas after the Baleno engine install: EDIT: more info 1. Check engine seems to come on when I'm at speed, between 80-100 so far and I put my foot down then it goes away once I turn the car off and back on, I pulled up and checked the diag code and it was 13 (ho2s) the O2 sensor is brand new and I have already checked the sensor voltages and wiring. The manual says to check anything that could affect A/F ratio so I will be attacking that first, starting with ignition I think!
2. Slightly rough idle about 1 minute after starting, stabbing the throttle causes the engine to rev up roughly but after a while comes good, feels like its running on 3 pots, I got this problem on and off tonight during normal driving until the engine was warm, could be related as well.
3. Car doesn't seem to "haul arse" as a few people have said the G16 does but it could all be related, also the engine has done 243k km (rebuild planned next year some time/whenever I get round to it) so may just be a little tired.
Users browsing this forum: Google [Bot] and 198 guests
