It is currently Sun Sep 20, 2026 11:55 pm
Vehicle: 1997 vit 1.6 16v
Post Posted: Sun Jun 02, 2013 9:41 pm
Iv started to notice im losing coolant. iv tracked back and it looks like its coming out near the intake manifold. could this just be a hose or is it somthing more serious?
Post Posted: Sun Jun 02, 2013 9:44 pm
hoses, or welsh plugs is a possibility
Vehicle: vitara
Post Posted: Sun Jun 02, 2013 9:51 pm
try n get a photo up and ill see if can see something.....
what I would do if I was you is get your engine as dry as possible and
then run it upto temperature and see if you can see wet spots. that might
lead you to your issue :0)
Vehicle: vitara
Post Posted: Sun Jun 02, 2013 9:56 pm
if I was you mate id try your engine down as best you can and then run it upto temperature and then see where its coming from.
might be worth getting some photos up of where you think its coming from
and get a second opinion.
Vehicle: vitara
Post Posted: Sun Jun 02, 2013 10:00 pm
I realized I repeated myself.lol dam stupid phone is doing my head in and the laptop packed up coiple weeks ago...
Post Posted: Sun Jun 02, 2013 10:06 pm
there is an edit button in the top right hand corner of your post & if no one has replied you can delete your post by hitting the X in the top right... but seeing i've posted this you can't do shit.
Vehicle: 85 ' Drover
Post Posted: Mon Jun 03, 2013 10:31 am
A quick way to find coolant leaks is a fitting attached to the top of the radiator with an air compressor attached.
Any mechanic should be ablt to do this for you in a couple of minutes, then you can see the coolant pouring out of the leak, where it otherwise might only drip.
Post Posted: Mon Jun 03, 2013 11:46 am
thanks for all your ideas iv tryed a few things this morning but still cant find it. im going to try what droverdave suggested and take it to a mechanic.
Post Posted: Mon Jun 03, 2013 6:17 pm
air compressors normally regulate out about 75 psi , cooling system 9-11 psi i wouldn't be pressurizing the cooling system to 75 psi . I normally pressurize it to 15 psi to check for leaks .
Users browsing this forum: Google [Bot] and 220 guests
