It is currently Sat Oct 03, 2026 9:15 am
Vehicle: MY2019 Jimny
Post Posted: Fri Feb 20, 2009 6:43 pm
This morning on my way home from work, I noticed that the lockright seemed to be undoing a bit more than usual, especially in a straight line.
Then i found that when I wasn't accelerating, there was a ticking sound coming from the diff.
Tyre pressures are identical by the way - this happened the last 3 kms home, what could it be?
Post Posted: Fri Feb 20, 2009 7:09 pm
You put it in the wrong diff, should have put it in the front :wink:
Mine has no problems onroad :thefinger:
Member of C.O.R 4x4
Post Posted: Fri Feb 20, 2009 7:39 pm
the shim on one side has worn down. they do that. will need to be re-shimmed.
Post Posted: Fri Feb 20, 2009 7:40 pm
is it still driving both wheels?
doesn't sound good. mine makes no noises when slowing down
it might pay to look for bits in the oil, might have munched a spring.
Post Posted: Fri Feb 20, 2009 9:47 pm
In one week? It was installed last thursday...
Yeah Ill have a look in the oil for crap.
What are mini spools worth?
Vehicle: 75 Cruiser
Post Posted: Fri Feb 20, 2009 10:33 pm
when you have a autolocker, nothing is normal :lol:
Post Posted: Sat Feb 21, 2009 3:59 am
i had a lockright lokka front and back in my old sierra, was always jumpin the back of the car around in carparks on tight turns, then i heard ticking in a straight line 4 a while, then i heard nothing & couldnt go round corners, it locked completely, took it back 2 4WD systems & i had somehow broken the pins in it? needless to say it was stuffed..
Download Sets @ http://www.johnpaul.3leggedcat.net
Post Posted: Sat Feb 21, 2009 6:21 am
You do know a mini spool is just like a welded diff.
Cons:
Still illegal.
Wears tyres.
Expensive version of a welded diff
Pro's:
Its a locker
It makes cool twists in axles.
No banging or clanging or grinding or shuddering or pinging or ponging or tinging.
:P
Post Posted: Sun Feb 22, 2009 10:33 pm
i have front and back lockright lockers have had them for ages find them to very good havent busted them yet
Post Posted: Sun Feb 22, 2009 10:41 pm
That's why they invented Air Locker's...
Users browsing this forum: No registered users and 206 guests
