It is currently Mon Jul 27, 2026 4:59 pm
Vehicle: 2013 JImny
Post Posted: Sun Jun 15, 2014 2:11 pm
Was driving the Jimny at about 50 kphr on some average corra. and a terrible metallic grinding,screeching sound started.
Was in 4wd,so changed to 2wd ,didn't make any difference .stopped the car and turned ignition on and off.Went about 30m fine then started again.
Kept it in 2wd and continued to happen until hit flat ground then stopped,now when i engage 4wd it locks in but i get a constant click click sound from the front left hub or wheel,the right is fine.
Mainly does it on rough uneven ground,on dead level surface doesn't seen to happen,i suppose its something to do with the vacuum hubs but can anyone elaborate or make further suggestions.
Got me stumped
Vehicle: suzuki jimny
Post Posted: Sun Jun 15, 2014 2:20 pm
Sorry dude but I'm stumped too
I'll be counting on the other boys to have the answer
Hope you find out what it is
Work to live, don't live to work.
Vehicle: 85 ' Drover
Post Posted: Sun Jun 15, 2014 2:42 pm
If you know its coming from the front left i would just start pulling it apart.
or at least jack up the wheel, grab the top and bottom of the wheel and see if you can feel any major clearance.
Could be a callapsed wheel bearing or pinion bearing.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sun Jun 15, 2014 5:18 pm
Jack the front left and see if your bearings are fucked. If they ar your wheel will have play in all directions.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sun Jun 15, 2014 5:19 pm
Oah and first check thes no 8-10 mm rocks stuck between the stone deflector and the disk break
Vehicle: Suzuki Jimny 2009
Post Posted: Sun Jun 15, 2014 6:31 pm
The front wheel bearings are pretty strong and they can stand a reasonable beating and this is a 2013 model car so I doubt this is a wheel bearing unless it is faulty. Sounds more like a hub issue. Also sounds a little like the problem Mirko is describing in the thread.
viewtopic.php?f=5&t=46605
I agree with Jezza to look for a stone caught up near the disc. Also check the vacuum hoses.
Post Posted: Sun Jun 15, 2014 6:32 pm
Sounds just like another thread started recently. I think both are probably just the auto hub not quite engaging properly.
I'd suggest a good test to rule out the hubs as the problem would be to remove the auto hub and take it for a drive. If the noise is gone that's most likely the problem.
Post Posted: Sun Jun 15, 2014 6:34 pm
Good suggestion Mr ZN!
Post Posted: Sun Jun 15, 2014 6:47 pm
I try ;)
Years ago, when my black Jimny was fairly new, I had a scrapie grinding noise coming from the wheels. I pulled the hubs to no avail. Ended up being the chrome dress rings I had on the stock rims, as the tyre rolled the sidewall bulge at the bottom would cause the bead to contact the ring which would rotate causing it to rotate on the rim creating metallic grinding sound.
Lesson learned; look for simple shit first.
Vehicle: Sj51t
Post Posted: Sun Jun 15, 2014 7:48 pm
I have had this happen a few times!
Post Posted: Mon Jun 16, 2014 3:17 am
But, Zukenutter, was that grinding of yours persistant or just occasional?
If it was about chrome dress rings, I assume, the noise was present all the time.
Mirko.
Post Posted: Mon Jun 16, 2014 5:46 am
good point
Post Posted: Mon Jun 16, 2014 6:28 am
Chrome rings was just an example of me (people) over complicating a diagnosis. Wasn't suggesting this was your problem.
Vehicle: 2013 JImny
Post Posted: Tue Jun 17, 2014 8:20 pm
thanks people,will see how i go with said suggestions
Users browsing this forum: Google [Bot] and 295 guests
