It is currently Tue Nov 03, 2026 7:33 pm
Vehicle: V6 autolocker rear and so much
Post Posted: Fri Jun 14, 2013 5:49 pm
I'm replacing my rears axle seals atm as thee leaking diff oil out, the bugger at the wing3r suzuki store sold me the wrong seals for a grand vitara which are bigger the the vitara seals.
I'm wondering if the wheel bearings are a sealed unit ? as my seals looked in good shape when i pulled them out so left me thinking the oil may be leaking from through the bearing ??? Also is there a seal in-between the bearing and the plate thing that bolts the axle into the housing ?
This pic is of my bearing on the axle which is still in very good working order with no play only the ball bearings are exposed, Should the be a side wall cover hiding the bearings internals ???
And a bad pic of my new rims a tires a picked up today :D
Users browsing this forum: No registered users and 478 guests
