| Are the rear wheel bearings on the SV620 a sealed bearing ? http://auszookers.com/forum/viewtopic.php?f=5&t=41418 |
| Author: | Chairman [ Fri Jun 14, 2013 5:49 pm ] |
| Post subject: | Are the rear wheel bearings on the SV620 a sealed bearing ? |
I'm replacing my rears axle seals atm as thee leaking diff oil out, the bugger at the wing3r suzuki store sold me the wrong seals for a grand vitara which are bigger the the vitara seals. Attachment: seal_min.jpg I'm wondering if the wheel bearings are a sealed unit ? as my seals looked in good shape when i pulled them out so left me thinking the oil may be leaking from through the bearing ??? Also is there a seal in-between the bearing and the plate thing that bolts the axle into the housing ? Attachment: brg_min.jpg Attachment: brng_min.jpg This pic is of my bearing on the axle which is still in very good working order with no play only the ball bearings are exposed, Should the be a side wall cover hiding the bearings internals ??? And a bad pic of my new rims a tires a picked up today Attachment: new.jpg
