It is currently Tue Nov 03, 2026 4:29 pm
Post Posted: Thu Jun 20, 2013 8:21 pm
Hi guys, I have some questions,
Question 1, I have a sierra transfer i want to put into my jimny, can it be done with out an ARO kit? Has anyone botherd to try?
Question 2, the sierra transfer i have has a drum on it for handbrake. Can i just use that handbrake instead of the one on wheels?
Any help would be great cheers Armsup
EDIT by a Mod: Readability.
Post Posted: Thu Jun 20, 2013 10:12 pm
I dnt know if anyone else have done it. But, youll need to design and fabicate the new mounts to adapt the case plus find a way (i dnt know how) to fix the speedo. Its not really worth it, unless u have the skills, the tools, the time, and want something to challenge
plus the ora kit is not that expensive. Just save a bit of money and buy it
Post Posted: Fri Jun 21, 2013 10:06 am
Ive just done it
and Ive made a jig to make them
I can make them in 1 of 3 different ways depending on what gearbox your running ect ect, Im in Brisbane too so not too far from you. For my conversion I moved the transfer forward 30mm to give more room for the sierra Front tail shaft to bolt in the rear and more room for the factory front jimny tail shaft to clear the gearbox cross member that is part of the chassis, also because mine is a 2008 my gbox output shaft spline was different to sierra so i had my factory Jack shaft shortend 90mm for $160 (can get it done cheaper though). I also moved it up higher so that the bottom of the transfer is above the bottom of the chassis rails just.
I'll be putting photos up in a about two weeks (Im heading away tomorrow for a weeks holidays atm)
Kyzer
Post Posted: Fri Jun 21, 2013 5:37 pm
how much would you charge to make the mount for me with leaver bent all ready to bolt in and my front shaft from sierra has a 2'' extention on it so ill probly have to change that back
isn't the ora kit like $800 posted to aus?
Post Posted: Fri Jun 21, 2013 8:31 pm
Nah mine was $354 to my door
Post Posted: Fri Jun 21, 2013 9:58 pm
i just looked on ora its like $600 aus $$$ now if it was $300 od have one allready
Vehicle: LJ50V, SJ70
Post Posted: Fri Jun 21, 2013 11:39 pm
Well just look again:
http://www.offroad-armory.com/store/ind ... uct_id=213
You don't pay VAT for export, so 165 pounds is around AU$275. Postage will add about AU$70.
Users browsing this forum: Google [Bot], Google Adsense [Bot], phlix and 254 guests
