It is currently Mon Sep 21, 2026 2:54 am
Post Posted: Sun Jul 07, 2013 2:38 pm
Installing vitara 4.6 ring and pinion to a sierra carrier and came across an issue. I know I've read about it here before but never payed any attention to what was the fix and I can't find it because a) I suck at searching.
And B) not really sure what to search for to find it.
Anyway my problem is this:
The vit ring gear doesn't retain the cross pins like the sierra one does. The vitara cross pin is retained by a roll pin.
I can see a fix by drilling and tapping for grub screws underneath the flange. But I'm not reinventing the wheel with this so after opinions from those that have been here before.
Post Posted: Sun Jul 07, 2013 2:45 pm
there is a retaining "can" that you can get from LROR & i think others have peened the edges of the carrier
http://www.lowrangeoffroad.com/index.ph ... -cans.html
Post Posted: Sun Jul 07, 2013 3:09 pm
A tack weld will hold it in place......
Post Posted: Tue Jul 09, 2013 3:54 pm
Too impatient to wait for parts from low range and not happy with the idea of welding it I went ahead with my original plan of drilling and tapping some recessed M5 threads to lock the pins with grub screws.
Post Posted: Tue Jul 09, 2013 4:14 pm
tidy work 8)
bit less booty fab than a tack weld too.
Post Posted: Tue Jul 09, 2013 5:33 pm
Nice work..... but.....
those pins are supposed to be able to rotate for better lubrication.
I have a retaining can here you can have if you still have your diff out.
Post Posted: Tue Jul 09, 2013 8:33 pm
Thanks for the offer jas, but I'm happy to give this setup a go. I don't see the shaft not turning causing any lubrication issues as the grooves in the shaft will let the oil into the bore of the gears. The vitara centre has the same grooves on the cross pin shaft and is located with a roll pin.
Post Posted: Tue Jul 09, 2013 8:58 pm
Go to a bearing joint. Get a couple of thick o-rings that are a tight fit. Roll them on between the carrier and ring gear. Done. About $1.50 worth of effort.
Post Posted: Tue Jul 09, 2013 9:11 pm
My effort was less. I done it at work while being paid! :P it only took about 15 minutes anyway.
Post Posted: Wed Jul 10, 2013 8:28 am
if they needed to rotate why do arb put pins through them in their air lockers?
Users browsing this forum: Bing [Bot] and 199 guests
