| Crank Sprocket http://auszookers.com/forum/viewtopic.php?f=5&t=41702 |
| Author: | jimmyjimny [ Wed Jul 03, 2013 4:21 pm ] |
| Post subject: | Crank Sprocket |
Hey guys I'm having trouble getting the crank sprocket off the crankshaft, I've stripped 2 bolts in it and need to replace it . I've got the bolt off no worries (which is meant to be the hardest part lol) but the sprocket seems wedged on the crank pretty tight. I tried a balancer puller and there wasn't enough clearance for it so I'm kinda stuck on what to try next. Is it just meant to slide off or do I need to get a pulley tool on it somehow? It's not the fanbelt pulley on the crank it's the sprocket that the timing belt goes on I was hoping I wouldn't need anymore special tools haha |
| Author: | atari4x4 [ Wed Jul 03, 2013 4:25 pm ] |
| Post subject: | Re: Crank Sprocket |
you can bolt the fanbelt pulley back on and use that to wiggle it off, if you're lucky. |
| Author: | Scrawny [ Wed Jul 03, 2013 6:00 pm ] |
Lots of penetrating oil and leave it to soak. It should just slide off |
| Author: | fordem [ Thu Jul 04, 2013 8:34 am ] |
I used a bit of flat stock with two holes drilled in it to make a puller - put the center bolt back in part way for the flat stock to press against and then screw two of the four/five bolts in and tighten them down evenly - when you've pulled it as far as it will come, move the center bolt out and start over. |
| Author: | shandy92 [ Thu Jul 04, 2013 3:31 pm ] |
like atari said, put the pulley on and give it a wiggle or a light love tap. mine just fell off. |
