It is currently Wed Oct 21, 2026 2:12 pm
Post new topic Reply to topic  [ 167 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
Vehicle: 95 Suzuki Vitara V6 2.0L Auto
Post Posted: Wed Jun 05, 2013 12:33 pm
Hello, i have a 1995 LWB Suzuki Vitara, V6 2L Automatic.
At the moment I am getting 250 – 270km to a 70L tank (really about 60L because I don’t drain it till it turns off). This is roughly 22L/100km and after reading reviews, they said it should be about 12L/100km. I understand that number is probably when it is new, but still, im sure it shouldn’t be as high as mine?
Is this fuel consumption normal for a car of this age? If not, what could I do to fix the fuel consumption?
Below is a list of part I have swapped out in attempt to improve the fuel economy. ALL PARTS where changed within a week of buying the car, and I bought the car 2 months ago:
- Throttle Body Cleaned
- Oil changed including new oil filter
- New Air Filter
- New Fuel Filter
- 6 Brand new spark plugs
- That is it I think…
Thank you.
Last edited by karlmarkiewicz on Wed Jun 05, 2013 12:40 pm, edited 1 time in total.
Post Posted: Wed Jun 05, 2013 12:38 pm
manual or auto?
pulled the error codes?
i'd be looking at the o2 sensors & are you accounting for the larger rolling diameter of non standard wheels?
Post Posted: Wed Jun 05, 2013 12:41 pm
manual or auto?
It's an Auto. I don't know what error codes are? :?
Yeah i was thinking of replacing the O2 sensors, but they are $150 each, which is a bit exy
Post Posted: Wed Jun 05, 2013 12:47 pm
what's going to work out cheaper... burning fuel @ 22l/100kms or a pair of o2 sensors, should be able to pick them up for around $100 each off ebay.. check 4wd products store out
Post Posted: Wed Jun 05, 2013 12:55 pm
I suppose i would just like to know whether they are going to make a significant difference or not.
I had a skim through those images, it seems as if i need a special tool, is this right?
Post Posted: Wed Jun 05, 2013 1:00 pm
no you can do it with a paper clip, last section of the first image walks you through the process.
if it comes up with an error for the o2 sensors, replace them.
one day when i finally start giving a shit again, i might put together a good tech how to on pulling error codes... but this show's the basics.
Post Posted: Wed Jun 05, 2013 1:14 pm
Oh Awesome! I will try it when i finish work tonight, and let you know how i go.
Thanks for that.
Post Posted: Wed Jun 05, 2013 8:55 pm
what about the throttle position sensor or the MAF?
Post Posted: Wed Jun 05, 2013 10:25 pm
It'll usually run pig rich with a failed MAF, you'll be able to smell the fuel in the exhaust
Post Posted: Fri Jun 07, 2013 11:51 am
MAF would come up on codes wouldn't it? Or only if it's completely cactus?
Long shot I know, but I had a caliper dragging on mine which was obviously stunting power and economy...
Post Posted: Fri Jun 07, 2013 12:18 pm
Thanks for that.
how did you get on with this??
Vehicle: '94 Sj413, 1.6 baleno convert
Post Posted: Fri Jun 07, 2013 5:19 pm
You can get cheap O2 sensors, almost all sensors I've seen on zooks are the same thread and diameter, I chucked a universal 4-wire sensor in my g16b with no problems, think I paid 40 or 50 for it shipped off eBay.
http://www.ebay.com.au/itm/OXYGEN-SENSO ... e9a&_uhb=1
Post Posted: Mon Jun 10, 2013 2:25 pm
It's not quite the smell of fuel, BUT i do always smell burning oil (i think that is what it is) whenever i go driving. The more i drive and the more i go high revs the stronger the smell. ALSO, sometimes there is a very tiny amount of smoke coming from the engine, which seems likely to be related to the burning oil. NOT SURE, if this is related to the fuel consumption, but i thought i would just mention it... I might have to post another thread later on about it XD
Soo SORRY! I have been super busy so i didn't get the chance to check them out. I will do it this afternoon i promise, hopefully the rain settles down. Either way, i should get back to you tonight :)
Wow, repco is a rip off then! That is alot cheaper. Thanks for that, might come in handy. :)
Thanks heaps everyone.
Post Posted: Mon Jun 10, 2013 2:27 pm
you can get plug & play o2 sensors for about the same price off ebay, check out 4wd products. the universal ones require a bit of a fiddly adaptor to join them in with the original wiring.
Post Posted: Mon Jun 10, 2013 3:30 pm
Oh awesome! I'm just about to start diagnosing it so we will.soon know whether I actually need one :)
Thanks
Post Posted: Mon Jun 10, 2013 4:37 pm
One question about the diagnostics. My car has two plugs each plug has its own little rubber cover. Although only one plug looks like the one in your video atari. Which one do I do it to? I have only done it to the one that looks like yours and I got the following pattern: blink"pause"blink blink. I couldn't find what that pattern means according to the images you sent me. The way I read it, it seems like.my error.code is 12 but i can't find 12 in the tables. Would you know what it is?
Thankd
Post Posted: Mon Jun 10, 2013 5:44 pm
12 is usually normal conditions, IE. no errors.
you will usually get a 12 if your check engine light never comes on.
If this is different in Vitaras I apologise but should be the same in nearly all zook ECUs.
Post Posted: Mon Jun 10, 2013 6:10 pm
2 plugs you say, one might be for the auto TCM. :?
i just checked my auto SV620 & there is only 1 plug by the airbox, it's a 6 pin plug & has 2 blue, 2 purple, 1 black, 1 white wires.
have you disconnected the battery recently as that will clear the codes & yeah from memory 12 means it's all clear.
Post Posted: Tue Jun 11, 2013 9:25 pm
Okay, thanks for that.
I took some photos of the plugs for a better description (See below). But basically i have that same plug as you do with 6 pins from it, but i also have a BLACK plug with 2 wire coming from it.
The video below is a video of the error code i am getting. TELL ME if the pictures or video are not viewable.
http://www.youtube.com/watch?v=UPEne_VV ... e=youtu.be
or
http://youtu.be/UPEne_VVpuI
Post Posted: Tue Jun 11, 2013 9:33 pm
weird, never seen the black plug in my travels, the clear/yellow is the one you want... i'm guessing the other one is for the auto, but it's strange mine doesn't have one being an auto too? :?
disconnect your battery for a few minutes & press the brake a few times to drain any residual current, this will clear the logged codes & give you a fresh base to start from.
on another note, what sort of fuel are you using?
mine runs like a bag of dicks on BP 98ron, has a weird hesitation/miss on start up when cold but with a tank full of Caltex 98 it won't do it & I'll get 50kms+ more out of the tank.
Post Posted: Tue Jun 11, 2013 9:46 pm
That is very weird :/ Possible something aftermarket the previous own added? I dunno. It's probably unimportant.
I disconnected the battery (Ground wire) before an after doing the test (the one you see in the video), but did not press on the brakes, i will try that another time.
I have only ever used 91 Unleaded, but i go to different fuel stations all the time, (e.g. BP, 7 Eleven, Caltex and Coles are the main ones). I have never used E10 because apparently it's shit, and haven;t used 98 because it's really expensive.
Post Posted: Tue Jun 11, 2013 9:49 pm
ahhh by disconnecting the battery before hand you've cleared any logged codes, hence it giving you a 12 (all clear).... give it a week or two & pull the codes.
you are living up to the reputation of suzuki owners being tight asses, put a tank of 98 in it & see how it goes.
Post Posted: Tue Jun 11, 2013 9:55 pm
Ahh okay, well yeah, i have been taking my battery on and off for about a week now trying to find a parasitic drain (i think it is my amplifier), so i will try again after not taking it out for a while. Thanks for that.
Hahahaha, yeah, okay. I will fill it totally up with 98 and see how it goes. Thanks.
Post Posted: Wed Jun 12, 2013 12:18 am
You can check your error code as soon as the check engine light comes on, even while your car is still running.
Post Posted: Wed Jun 12, 2013 8:55 am
Oh okay. How do you do that? Just start the car and look at what the engine light does?
Post Posted: Wed Jun 12, 2013 12:38 pm
Yes, same thing as Atari has mentioned, by shorting the diagnostic connector pins, I was just saying you can do it with he car running as well.
Post Posted: Wed Jun 12, 2013 12:45 pm
personally i wouldn't do it, you'd think the FSM would mention it if it was the thing to do?
Post Posted: Wed Jun 12, 2013 12:55 pm
I can guarantee it wont cause any problems, have done it many times on different models, including Vits.
The reason I mentioned this option is because some faults clear as soon as you turn the ignition off, leaving you unable to recover the code.
Post Posted: Wed Jul 03, 2013 1:11 pm
Alright Guys, i think I have found something.
I followed what Atari said and I just drove my car normally without removing the battery for about a week, just to see if any more error codes came up... And one did! :D
I am currently at work so it is a bit difficult for me to upload the video of the error code, but this is the one and only code pattern i am getting: blink *pause* blink-blink-blink
Now, the way i understood the manual that Atari posted, this error code pattern would equal a code 13. Which, i think, is a HO2S problem (see the attached image for the part of the table i read).
Could you guys please confirm this error code with me, and maybe tell me what parts need to be replaced? I will post video when i get home.
Thank you so much!!
Post Posted: Wed Jul 03, 2013 1:14 pm
On a side note, I tried 98 fuel. Although i did a mix of Urban, Highway and beach driving i am pretty sure 98 wasn't a huge difference. Definitely not saving $15 when compared to 91 ($15 is the price difference between the two on a Full tank).
Users browsing this forum: No registered users and 107 guests
