| sway bar doesn't fit after 2" lift http://auszookers.com/forum/viewtopic.php?f=5&t=41758 |
| Author: | jzanuttini [ Sat Jul 06, 2013 3:44 pm ] |
| Post subject: | sway bar doesn't fit after 2" lift |
i put a 2" lift in my 94 wt sierra. And it when in pretty smooth, but now my sway bar doesnt fit back in to its right spot! can anyone tell me how i can get it back in please! |
| Author: | jono165 [ Sat Jul 06, 2013 3:52 pm ] |
| Post subject: | Re: sway bar doesn't fit after 2" lift |
Some companies have a listing for a shim that installs in the swaybar bracket as a spacer to space the front of the swaybar down so it will still bolt up, its really just a bit of flat plate with some holes drilled in it which could be easily made at home. Alot of poeple on here have ditched the swaybar and run without it to get the front end to flex more, maybe take it for a quick drive and see what you think, lifted springs have more spring rate so it might drive the same without it. |
| Author: | jzanuttini [ Sat Jul 06, 2013 3:55 pm ] |
yeah thats what i thought, i just thought i would see what others have to say about it. |
| Author: | SuziBlu [ Sat Jul 06, 2013 4:14 pm ] |
Leave it off. |
| Author: | atari4x4 [ Sat Jul 06, 2013 4:16 pm ] |
SuziBlu wrote: Leave it off.
| Author: | Mike_B [ Sun Jul 07, 2013 8:51 am ] |
On my Vit the sway bar still fitted, but with the link removed the front does flex a bit better off road, and wit the stronger springs it is still good on the road, so leave it off. |
