It is currently Mon Sep 21, 2026 5:58 am
Post Posted: Sun Jul 07, 2013 8:04 pm
Hello everyone,
i'm trying do decide how to upgrade my axles for 33" tyres and i missing some info, hope you guys can help:
first, weight-suzuki samurai wt axle vs. toyota hilux axle (fully loaded with brakes) front and rear.
scond, width specs for wt vs. toy vs. jimny.
last - ground clearance from ground to diff - suzuki wt vs. toy both with 33".
i know diff cover can be moded on both axles, how much clearance can be gaind in both suzuki and toyota axles?
I'll appriciate your help.
and info you got just put in or link me to..
thanks!
Post Posted: Mon Jul 08, 2013 8:03 am
WT front with CrMo axles and WT rear either standard or upgraded axles will be OK on 33's as long as you drive sensibly.
Post Posted: Tue Jul 09, 2013 6:52 pm
I understand the that zuk axle with chromo can handle 33.
But i had specific question which im eager to find answeres to.
How much different clearence under the zuk diff and hiw under toy, and how much more clearence can be gain by mod the buttom of each diff cover.
Second how much weight diff rent between the to axles.
Thanks.
Ori.
Post Posted: Wed Jul 10, 2013 5:39 am
You'll find axle widths and weights in here.
search.php
Post Posted: Wed Jul 10, 2013 10:03 am
Suzuki sierra complete diff housing/hubs/etc Front 80kg Rear 63.5kg
Hilux complete diff housing/axles etc Front 107kg Rear 92kg
viewtopic.php?f=5&t=23448&p=639482&hilit=Weights#p639482
Wheel mount surface widths.
Sierra WT
Front 1340mm
Rear 1350mm
Hilux (79-85)
Front 1397mm
Rear 1397mm
Jimny
Front: 1355 mm
Rear: 1365 mm
Wheel Base: 2250mm
viewtopic.php?f=17&t=7678
There is many debates on ground clearance.
With light shaving i bet you will be able to come to same clearance as stock suzuki wt axles.
Users browsing this forum: No registered users and 145 guests
