As the title suggests, a mate has a 1999 Vitara wagon and the CHECK ENGINE light comes on, he has been to a mechanic and the scan tool says 051 EGR. When he checked with SUZUKI, a replacement cost of $549.00 was quoted. Does the EGR need to be replaced or can it be serviced/ cleaned? Alternately, can you get aftermarket parts?
Joined: Tue Aug 08, 2006 11:30 pm Posts: 5517 Location: Holland Park
Posted: Tue Jul 09, 2013 11:10 pm
It is most likely that the EGR valve/port is fully blocked with carbon or something like that. I'd suggest you pull it off and clean it out including the ports.
Joined: Mon May 16, 2011 7:03 pm Posts: 686 Location: Brinkworth, England
Posted: Wed Jul 10, 2013 5:04 am
^ what he said. Code 51 means that there is a problem with the EGR system, it doesn't necessarily mean a problem with the EGR valve itself. Code 51 is almost always coked up passageways.
Thankyou for the replies. Any suggestions as to what to use as a cleaning agent? Will we need any gaskets? Also do we only need to clean the EGR valve area in the manifold?
Users browsing this forum: No registered users and 183 guests
