| VITARA H25 CHECK ENGINE LIGHT....... HELP PLEASE? http://auszookers.com/forum/viewtopic.php?f=5&t=41833 |
| Author: | Boggomobile [ Tue Jul 09, 2013 10:30 pm ] |
| Post subject: | VITARA H25 CHECK ENGINE LIGHT....... HELP PLEASE? |
Hi All, As the title suggests, a mate has a 1999 Vitara wagon and the CHECK ENGINE light comes on, he has been to a mechanic and the scan tool says 051 EGR. When he checked with SUZUKI, a replacement cost of $549.00 was quoted. Does the EGR need to be replaced or can it be serviced/ cleaned? Alternately, can you get aftermarket parts? Any help would be greatly appreciated. Thanks in advance. |
| Author: | JrZook [ Tue Jul 09, 2013 11:10 pm ] |
| Post subject: | Re: VITARA H25 CHECK ENGINE LIGHT....... HELP PLEASE? |
It is most likely that the EGR valve/port is fully blocked with carbon or something like that. I'd suggest you pull it off and clean it out including the ports. |
| Author: | Rhinoman [ Wed Jul 10, 2013 5:04 am ] |
^ what he said. Code 51 means that there is a problem with the EGR system, it doesn't necessarily mean a problem with the EGR valve itself. Code 51 is almost always coked up passageways. |
| Author: | Boggomobile [ Wed Jul 10, 2013 7:35 am ] |
Hi All, Thankyou for the replies. Any suggestions as to what to use as a cleaning agent? Will we need any gaskets? Also do we only need to clean the EGR valve area in the manifold? |
| Author: | Rhinoman [ Wed Jul 10, 2013 5:22 pm ] |
I'd use carb cleaner, theres a metal gasket, you might as well replace that while its off. |
| Author: | Boggomobile [ Fri Jul 12, 2013 7:23 am ] |
Rhinoman wrote: I'd use carb cleaner, theres a metal gasket, you might as well replace that while its off. Thankyou Rhiniman and JrZook, We are definitely living in a smaller world, will attempt a cleaning job this weekend. |
