It is currently Thu Oct 01, 2026 5:55 pm
Post Posted: Fri Feb 27, 2009 5:38 pm
my passenger side front tyre stopped driving a couple off weeks ago.
i was trying to reverse snatch a cruser out of a bog and heard a click and then no drive. i have just got around to looking at it, i suspected the the lockright had broken the pins or something as there were no noises at all coming out off the diff when the hubs where locked. anyhow i just pulled the axle and the CV is kactus it hadn't disintegrated but every bit i can see has cracks in it.
is it possible for a CV to die and not make much noise, i do always have the aircon on and i am a bit deaf though. or should i slave in 40 deg heat with 99%
humidity and yank out the center for a look. :roll:
Vehicle: 75 Cruiser
Post Posted: Fri Feb 27, 2009 7:22 pm
what bit has the cracks? but anyway, yeah it's probably rounded off the splines on the shaft, so the shaft just spins.
Post Posted: Fri Feb 27, 2009 7:39 pm
all the bits have cracks. after giving it a hit with a pressure washer
i can see that it is expanding where the spline is.
Vehicle: 75 Cruiser
Post Posted: Fri Feb 27, 2009 7:45 pm
bwaha nice work.
yeah, once the inside bits crack the axle spins and stuffs the splines.
Throw it in the bin... or make a trophy out of it :)
Post Posted: Fri Feb 27, 2009 7:52 pm
so you thing the axle will be stuffed. i bladdy hope not as there are no wt axles around here i have a spare short side but guess which axle this is. :roll:
Vehicle: 75 Cruiser
Post Posted: Fri Feb 27, 2009 7:55 pm
remove everythng and check the splines ... and i'll have a woodie :cheers:
Post Posted: Fri Feb 27, 2009 7:58 pm
think i might just throw it at balls slave oops i mean work experience kid and say fix, or we will make you drive the wheelie daddo. :lol:
Vehicle: 75 Cruiser
Post Posted: Fri Feb 27, 2009 8:00 pm
hilux diffs: $500 8)
Post Posted: Fri Feb 27, 2009 8:18 pm
bit off a clean up with a file and everything will be sweet. maybe.
Vehicle: 75 Cruiser
Post Posted: Fri Feb 27, 2009 8:23 pm
bwahaha you did a nice job on that one :lol:
Post Posted: Fri Feb 27, 2009 11:10 pm
nope
you lunched it, make a door stop out it
Post Posted: Sat Feb 28, 2009 12:06 am
hay ball how about you put the smoke back in your lathe (electrical fire)
and make me a shiny new one.
Post Posted: Sat Feb 28, 2009 12:30 am
I was thinking the same thing on my way home.
Bring it down tomorrow so I can have a look. I know where I can get my hands on some good axle material.
Vehicle: WR250F/Jeep XJ
Post Posted: Sat Feb 28, 2009 12:34 am
Shep I got a pair, passenger side and drivers side axles and cvs I can send your way for $150+shipping.
PM sent with pics.
Post Posted: Sat Feb 28, 2009 3:17 am
You have been taking rough lessons from Mad Kenny 8O
Post Posted: Sat Feb 28, 2009 3:32 am
he was working as ballast when i busted it
Users browsing this forum: No registered users and 102 guests
