| What offset to get for Vitara (15x8 with 31x10.5 tires) http://auszookers.com/forum/viewtopic.php?f=5&t=41999 |
| Author: | multimaster [ Thu Jul 18, 2013 5:54 pm ] |
| Post subject: | What offset to get for Vitara (15x8 with 31x10.5 tires) |
Hi guys Just wondering what offset to get on 15x8 rims to put on a 95 LWB vitara to do minimal guard bashing. It's gunnu get a 2 inch body and 2 inch suspension lift. I don't mind if they stick out a bit, I'm more than happy to get flares. It'll be used 70% Road, 30% Fun. Cheers |
| Author: | atari4x4 [ Thu Jul 18, 2013 5:58 pm ] |
| Post subject: | Re: What offset to get for Vitara (15x8 with 31x10.5 tires) |
why 15x8's?, personally i'd be getting a 15x7 for a 10.5" wide tyre. |
| Author: | sideways [ Thu Jul 18, 2013 6:02 pm ] |
atari4x4 wrote: why 15x8's?, personally i'd be getting a 15x7 for a 10.5" wide tyre. +1 My Sunnies are a 15x7 -6 offset. They used to be on Joes SWB vit with 30x9.5s. $62 each from Tyre Power for the white ones, pretty sure black ones were $80 or something like that. |
| Author: | multimaster [ Thu Jul 18, 2013 6:16 pm ] |
atari4x4 wrote: why 15x8's?, personally i'd be getting a 15x7 for a 10.5" wide tyre. Oh righto, I thought i read somewhere to put a 10.5 on a 7-9 inch rim with 8.5 preferred. Either way, what offset would i get on a 7 inch or 8 inch. Thanks |
| Author: | atari4x4 [ Thu Jul 18, 2013 6:32 pm ] |
i run a -15 15x7 & have a fair bit of "poke" which does wonders for stability. |
| Author: | multimaster [ Thu Jul 18, 2013 6:39 pm ] |
Sorry mate, not really up to date with my jargon. What do you mean by poke? |
| Author: | atari4x4 [ Thu Jul 18, 2013 6:44 pm ] |
poke = they stick out a fair bit standard vitara rims are +25 15"x5.5"'s |
| Author: | multimaster [ Thu Jul 18, 2013 6:51 pm ] |
Oh righto, Probably shoulda guessed that. I was thinking -13 on the 15x8s. Do you find you get a bit of tyre bulge from the 10.5s on the 7 inch rim? Most of my driving is highway so I don't want to jeopardize my onroad handling too much. I'm gunnu get 75mm flares off ebay so I spose it won't really matter too much if they stick out up to 2-3 inches. |
| Author: | atari4x4 [ Thu Jul 18, 2013 7:00 pm ] |
i'd be looking at a 15x7 with an offset around -12 to -15 if you want something to counter act the lift as there is no need for a 15x8 on a 10.5" tyre & if you were stepping upto a 15x8 you'd need something like -22 or greater to get the same sort of wheel track increase. i really doubt you'd notice the difference with road holding, but where the 15x8's will come unstuck compared to a 15x7 would be when you're aired down as there will be less pressure on the beads & the chances or rolling a rim off the tyre could be greater. |
| Author: | SierraDan [ Thu Jul 18, 2013 7:03 pm ] |
atari4x4 wrote: where the 15x8's will come unstuck compared to a 15x7 would be when you're aired down as there will be less pressure on the beads & the chances or rolling a rim off the tyre could be greater. I agree with everything except this. I found the 15x7 to be just as bad as 15x8. |
| Author: | atari4x4 [ Thu Jul 18, 2013 7:08 pm ] |
out of interest, were they new fresh tyres or had they been stripped & mounted a few times? |
| Author: | multimaster [ Thu Jul 18, 2013 7:12 pm ] |
Fresh tyres, what difference would it make? |
| Author: | atari4x4 [ Thu Jul 18, 2013 7:14 pm ] |
the beads get stretch mounting & unmounting tyres |
| Author: | SierraDan [ Thu Jul 18, 2013 8:15 pm ] |
atari4x4 wrote: out of interest, were they new fresh tyres or had they been stripped & mounted a few times? By the condition when i got them, i would assume they were mounted to those rims only. Then recently changed to the 8" |
| Author: | SierraDan [ Thu Jul 18, 2013 8:18 pm ] |
Actually no. Josh had the rims seperate when he painted them the yuk colour haha |
| Author: | got_bar_work [ Mon Jul 22, 2013 7:48 am ] |
15X7 10p will be the best fit for least amout of cutting but the -13 will allow more stability |
