It is currently Thu Oct 01, 2026 8:07 pm
Post Posted: Sun Mar 01, 2009 5:16 pm
Newbie question - never had to pull a diff out before.
Vitara rear diff.
I've got the axles out (hanging out the housing by about a foot), undone the nuts around the diff flange, and taken off driveshaft and the A frame balljoint.
I've tried driving a thin steel wedge between the diff flange and the housing, but it just doesn't seem to budge.
Double checked that I have all the nuts off the flange.
Am I missing something or is it just a case of stuck on the flange sealant and more force required to separate it.
Steve
Vehicle: MY2019 Jimny
Post Posted: Sun Mar 01, 2009 6:48 pm
Give it a good hoik... It should come out once the gasket is broken.
Make sure your car is well supported first though...
yeah it might need a good wak near the flange to loosen it, if your axles are out & ALL of the bolts/nuts are off it should move.
the 1st one i pulled came apart easy, the 2nd one was a bitch!
Post Posted: Sun Mar 01, 2009 7:58 pm
Thanks guys. Its out now.
Wouldn't budge until I drove the flange bolts back into the housing a bit. Took a pretty hefty smack with a hammer and drift to get them to move too.
Now for the front one....
Steve
Post Posted: Sun Mar 01, 2009 8:14 pm
Best way i've found to crack that seal is to put a jack under the flange. You only need to give it a little pressure and it breaks the seal easy.
Post Posted: Sun Mar 01, 2009 10:35 pm
Thanks Damo - I'll try and remember that for next time.
Post Posted: Sun Mar 01, 2009 11:48 pm
if youve had teh axles hanging in the housing like that replace teh axle seals you jsut destroyed, otherwise your brakes will either get oily or catch fire :)
Post Posted: Mon Mar 02, 2009 12:45 am
Thanks Royce. I hadn't thought about damaging the seal but its a good point.
I've just had another look and there is a smaller diameter ring with lots of holes on the inboard side of the seal and it looks like the axle was sitting on that rather than on the seal.
Not a drama in this case anyway as the car is just being stripped for parts.
Users browsing this forum: Google [Bot] and 151 guests
