It is currently Fri Nov 20, 2026 9:30 pm
Vehicle: 75 Cruiser
Post Posted: Sun Oct 08, 2006 10:25 pm
i got the switches in today....
The front locker switch has the front and back of it updside down compared to the others, so it has to be in the off position to be working.
I assume you can take the front off and clip it on the other way? but i didn't want to force it incase it broke.
any one know anything about them?
Post Posted: Sun Oct 08, 2006 10:38 pm
does it light up back to front of the others? IE the big blue bit lights up with the lights and the little one lights up when on?
Vehicle: 75 Cruiser
Post Posted: Sun Oct 08, 2006 11:12 pm
well i haven't connected the dash light wire, just the ignition power wire.
but the bottom of the switch lights up when in the off position,
and is letting air through.
Post Posted: Sun Oct 08, 2006 11:16 pm
yeah its upside down, just pop the front off (look at the side youll see how its held on, just pull it up with your finger) put back on 180* then turn the whole switch 180*
the covers come off pretty easy, I think it would be hard to break one
Post Posted: Mon Oct 09, 2006 11:34 pm
ARb shop told me they break easily. maybe once they have been used for a couple of years etc, probably come off easier.
Vitara driver...
Post Posted: Wed Oct 11, 2006 1:14 am
Just take it to any ARB dealer and they should replace it, obviously a manufacturing error therefore they should cover it.
Post Posted: Wed Oct 11, 2006 1:51 am
the covers arent fitted to the switch when you buy the locker, cause some lockers fit front and rear so you get 2 covers.....
Vehicle: Suzuki Grand Vitara
Post Posted: Fri Oct 13, 2006 2:11 pm
There are two little holes/tabs on the cover that click over poles on the switch,
just use something pointy to push one of the tabs sideways a bit and it should pop off....
Users browsing this forum: Google [Bot] and 40 guests
