| Suzuki Sierra GTI Mazda Distributor Cap Help. http://auszookers.com/forum/viewtopic.php?f=5&t=42125 |
| Author: | TweakV2 [ Wed Jul 24, 2013 6:21 pm ] |
| Post subject: | Suzuki Sierra GTI Mazda Distributor Cap Help. |
My GTI engine will run with the gti distributor cap on and with the mazda rotor button, but when I put the Mazda cap on it won't run until I advance the timing to 20 degrees. |
| Author: | matty_wall [ Wed Jul 24, 2013 6:27 pm ] |
| Post subject: | Re: Suzuki Sierra GTI Mazda Distributor Cap Help. |
So you havent made a hybrid rotor button out of the two? |
| Author: | TweakV2 [ Wed Jul 24, 2013 6:35 pm ] |
Yea I took the centre out of the gti rotor button and pressed it into the Mazda rotor button. It clears fine in the gti cap. |
| Author: | matty_wall [ Wed Jul 24, 2013 6:50 pm ] |
and the hole for screwing the rotor button into the distributor is in the exact position in relation to the button as the original GTI rotor button? thats the only thing I can think of that would be a problem. |
| Author: | TweakV2 [ Wed Jul 24, 2013 6:55 pm ] |
Yea it certainly is made sure of that. Would a weak coil do this? |
| Author: | matty_wall [ Wed Jul 24, 2013 7:16 pm ] |
Iunno. I gots nothing... Sorry. |
| Author: | ZUK12A [ Thu Jul 25, 2013 8:38 am ] |
Is this the rotor button you guys are using to mod? http://www.ebay.com.au/itm/Mazda-323-BF ... 461118dbd9 |
| Author: | TweakV2 [ Thu Jul 25, 2013 9:11 am ] |
Yes, that is the rotor button we use. Because the post in the Mazda Cap is solid it needs the spring contact in the rotor button. But we use the centre out of the gti rotor button to hold it in place. |
| Author: | ZUK12A [ Thu Jul 25, 2013 9:25 am ] |
sweet. I have to get one for mine, I only have the cap at the moment. good luck with your issue, keen to hear how you get it sorted. |
| Author: | Dillbert [ Fri Jul 26, 2013 11:47 am ] |
we are having trouble doing this as the hight of the rotor will not let the cap sit flush & how do we keep the bush tight in the rotor, any help would be great with photos please |
| Author: | TweakV2 [ Fri Jul 26, 2013 1:57 pm ] |
Found the problem. Spark was jumping from rotor button to distributor shaft. Remember to insulate well! |
| Author: | BigSammy [ Fri Feb 17, 2023 8:07 am ] |
Hi,is there by any chance a photo to confirm the exact mazda rotor position in relation to swift rotor to shaft? THanks |
