It is currently Thu Jul 30, 2026 6:44 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page 1, 2  Next
Vehicle: 92 WT sierra
Post Posted: Sat Aug 10, 2013 4:51 pm
Hey guys,
Ive searched but havent found enough info i plan to run a vit 3 speed auto an transfer with a sierra 6.5 case behind i was looking for a link to a complete build cant seem to find anything thanks in advance guys
Post Posted: Sat Aug 10, 2013 9:17 pm
Talk to Joblow. On here.
Post Posted: Sun Aug 11, 2013 7:18 am
Look up 'yellow thing' in Rigs section
Post Posted: Sun Aug 11, 2013 8:28 am
Thanks guys will do let u know how i go
Post Posted: Sun Aug 11, 2013 11:25 am
Unless you are planning 35"+ tyres, a trimatic and 6.5 transfer gears don't really make for a happy car on the highway - it's revving far too high. If you are planning big tyres, then the vitara low range (by itself) is pretty useless.
If you really want to pursue dual cases, I'd be gearing the sierra case taller - maybe 4.1 gears or stock 1.0 transfer gears, so you have better high range for road use and can use all the ranges.
Or just put an AW-4 in it with one transfer and call it good.
Just my 2C. I think duals are a poor return for the effort.
Post Posted: Sun Aug 11, 2013 12:08 pm
If its who I think it is, its got 37" Creepies and wont see the road.
Post Posted: Sun Aug 11, 2013 12:11 pm
Wow, I hope it's got some power then or it won't be pulling the vitara low range.
Post Posted: Sun Aug 11, 2013 12:16 pm
1.3 on gas I think.
Twin transfer.
Post Posted: Sun Aug 11, 2013 12:46 pm
A 12.35:1 low range isn't going to be any good for anything.
Post Posted: Sun Aug 11, 2013 12:52 pm
It'll be good for Marlin Crawler style videos..
You can get your chart out and figure out what gear you're in :lol:
Post Posted: Sun Aug 11, 2013 1:48 pm
Exactly. Like drop shackles etc - posing.
I'm at 100:1 + converter and it's as low as anyone could ever need. Near-as doubling that isn't going to help capability in any way.
Post Posted: Sun Aug 11, 2013 2:53 pm
No guys its not 1.3 on gas yes 37 creepies its the bigblock 1.6 and no it will never be on the road again
Post Posted: Sun Aug 11, 2013 3:00 pm
Mine will be 85:1, with an auto will be plenty.
Post Posted: Sun Aug 11, 2013 3:51 pm
For sure. Probs more practical than my 100:1.
Post Posted: Sun Aug 11, 2013 10:29 pm
I'll have around 60:1 plus auto on 33's. But I doubt I'll do too much crawling with it.
Post Posted: Mon Aug 12, 2013 1:31 pm
I've seen plenty of trucks on pirate with over 200:1 and think wtf
12.35:1 A hell of a lot for only 37
Will the sierra case take that much torque
Post Posted: Mon Aug 12, 2013 1:34 pm
With the converter slipping I'm at 240:1.
I can't be bothered with 1st low most of the time. Even descending steep hills.
Post Posted: Thu Aug 15, 2013 7:48 am
I run a g16b, aw4, Vit transfer, 1L transfer, 4.6 diffs and 33's I find this to be quite satisfactory or in laymans terms 'FUCKING AWESOME'. Sure it's a bit more work but nothing good comes easily and it seems you're not afraid to get your hands dirty so go for it. Of corse if you want it to be super awesome you could always put some speed holes in it and paint it garden shed green. :)
Post Posted: Thu Aug 15, 2013 8:06 am
Sure, but that's not a 1.3, vitara low range, 6.5's and 37" tyres. No amount of speed holes or shed green will make that combo awesome.
Post Posted: Thu Aug 15, 2013 8:20 am
kenn, I'm curious as to how much you would actually use just the low range of the vit case which from what ive worked out is about 2.8:1 with the 1L case in high range. With an auto it doesnt seem like it would be all that useful give than low-low range is about 4.5:1. I currently have 5.14:1 transfer gears and I pretty much have 10 different forward gears (ie low 5th is slightly lower than 1st high) which gives a good spread by itself without a 2nd case.
I understand its a bit of work to build but the effort vs return is kinda low if its not used often in all the ranges given and off the shelf gearset it relatively cheap and still allows a rear driveshaft thats a decent length.
Post Posted: Thu Aug 15, 2013 9:12 am
Putting the vitara transfer ahead of the sierra transfer keeps the SWB tailshaft a satisfactory length.
Post Posted: Thu Aug 15, 2013 9:27 am
pinched from kenn's build. his tailshaft is rather short but it depend on how much travel the suspension is built for too. I'm assuming a SWB sierra tailshaft will be slightly longer.
Post Posted: Thu Aug 15, 2013 9:38 am
kenns is in an LJ though which standard are a fair bit shorter WB. im not 100% sure what Kenns WB is however.
Post Posted: Thu Aug 15, 2013 9:48 am
I understand that, I've just had a look factory wheelbase of a sierra is 4" longer than an lj80, I thought it was less than that.
I'm more interested to see how often kenn uses just the low range of the vit case, Ive always found only having 2 ranges to choose from fine. A 2.8:1 low range might be pretty handy for sand though which I haven't really driven on.
Post Posted: Thu Aug 15, 2013 10:18 am
For the record, my calls on Kenns transfer combinations are:
1.59
2.55
2.86
4.61
Steve
Post Posted: Thu Aug 15, 2013 10:36 am
i've got duals in my build and will be looking at
1.58
2.84
4.16
7.48
im running 4.1 transfer gears in the sierra case. 4.6 diff gears and either 35s or 37s
i have 119:1 in my LJ50 and would actually like slightly lower first gear if i could get it.
alot depends what you will be driving on terrain wise.
Post Posted: Thu Aug 15, 2013 12:21 pm
We both use ours everytime we are offroad. Sometimes we want just vit low, sometimes Sierra low. In the ten years mine has been in I haven't touched it. I lie......I have changed the oils. Kenns is probably the better setup as his is air operated.....just turn a switch. It also gives us the ability to have low range two wheel drive without messing with the Sierra case. We run them because its just like giving someone a holesaw and drill.......because we can.
Post Posted: Thu Aug 15, 2013 6:31 pm
Speaking of tail shafts with dual cases
my shaft looks like it will be around 750mm long and about 150mm offset because of the vit diff and the offset sierra output
will this work or will joe need to make me a offset vit diff
Post Posted: Thu Aug 15, 2013 6:33 pm
Offset vitara diff would be easy to do
Post Posted: Thu Aug 15, 2013 6:39 pm
Plz tell
U could cut 70mm off a gv diff but its still not enough
Users browsing this forum: No registered users and 204 guests
