| 12V Auto LED Lights Voltages and other Technical Learnings. http://auszookers.com/forum/viewtopic.php?f=5&t=42470 |
| Author: | royce [ Wed Aug 14, 2013 6:51 pm ] |
| Post subject: | Re: 12V Auto LED Lights Voltages and other Technical Learnin |
I reckon the flasher was the cause of your low voltage, do you have a pic of the indicators running LED? there is a big variance in outputs so it would be good to keep track of ones that work well I had something like this in the Vit for reverse, worked well with the way the bulb points straight out. http://www.ebay.com.au/itm/BA15S-1156-3 ... 9bd&_uhb=1 |
| Author: | atari4x4 [ Wed Aug 14, 2013 7:01 pm ] |
royce wrote: I had something like this in the Vit for reverse, worked well with the way the bulb points straight out. http://www.ebay.com.au/itm/BA15S-1156-3 ... 9bd&_uhb=1 will report on the kwality of light output when they arrive. |
| Author: | christover1 [ Wed Aug 14, 2013 10:32 pm ] |
My flasher can had written on it max 4 globes. My Vit has 4 per side plus trailer. It wasn't a stock can, it was cabled tied to a bunch of wires. Trailer lights improved vastly after fitting the new flasher can, but improved more going to led globes on Vits indicators. Don't want bright lights in reverse, have chosen softer light for them, because I wanted trailer reverse lights brighter than cars. Reason being, cars reverse lights lit up trailer, and was hard to see past trailer. Have fitted camera onto trailer, which comes on with reverse. I have a 2nd 10Watt cree reverse light, for when trailer not on. Don't need the Stop/Tail Led's, but can't hurt. http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 1255741900
| Author: | atari4x4 [ Thu Aug 29, 2013 11:06 pm ] |
atari4x4 wrote: royce wrote: I had something like this in the Vit for reverse, worked well with the way the bulb points straight out. http://www.ebay.com.au/itm/BA15S-1156-3 ... 9bd&_uhb=1 will report on the kwality of light output when they arrive. they rocked up this arvo while at work... will try & fit them up tomorrow. took 15 days from china.
| Author: | christover1 [ Thu Aug 29, 2013 11:13 pm ] |
They look stronger. Mine were a bit flimsy. I took out the stop/tails, weren't bright enough in daylight. Indicators, parkers, and reverse ones are excellent, though. |
| Author: | atari4x4 [ Fri Aug 30, 2013 10:56 am ] |
both bulbs but the iphone exposure is off ![]() left = LED right = bulb ![]()
| Author: | christover1 [ Fri Aug 30, 2013 11:04 am ] |
Definitely whiter. I'm finding the whiter light better for my reverse cam, too. |
| Author: | Blakey [ Fri Aug 30, 2013 4:54 pm ] |
you will be better off with these http://www.ebay.com.au/itm/2PCS-1156-50 ... ee5&_uhb=1 if you actually want something brighter then standard. and i do doubt they are 50W they would melt if they actually were. |
| Author: | sideways [ Fri Aug 30, 2013 6:11 pm ] |
Blakey wrote: you will be better off with these http://www.ebay.com.au/itm/2PCS-1156-50 ... ee5&_uhb=1 if you actually want something brighter then standard. and i do doubt they are 50W they would melt if they actually were. 12x0.7 = 8.4w That's a long way off 50w. |
| Author: | Bugsta [ Fri Aug 30, 2013 7:03 pm ] |
They could be referring to equivalent in incandescent. They just don't make that clear. |
