You will need to have fitted NEW seat belts and the mounts must be the STD ones for them and the seats if not you may need to go to a QT Engineer if all is ok the Certification should cost for the Mod Plate & Certificate around $50-$70 but if and QT engineer has to inspect it $100-$300 that is when I use to do it some 4 years ago. Check around for prices and some guys will allow old seat belts if they are desperate for the $$$$$. It is Illeagel to sell seat belts at a wreckers/Etc. if they know you are going to use them in a car. they can sell them for tie down straps though.
_________________ Steve W
In that case no problems just plug all mounting holes ( Put The Bolts back)and take it to someone that is Certified to do it and you should be gone in 10-15 min and $50-$60 lighter in the pocket
Users browsing this forum: No registered users and 24 guests
