It is currently Wed Jul 29, 2026 9:28 pm
Vehicle: Vitara 1990 SWB Soft Top
Post Posted: Wed Aug 21, 2013 10:56 pm
Hi Zookers...
Starting to get things back together on the vitara and sprucing things up as i go along.
I pretty much pulled out everything that can be from the engine bay and given it a good coat of Satin Black... Looking Pretty Schmick...
The Brake Booster looks pretty average so I pulled it out for a good clean up and lick of paint.
A few questions... Can someone tell me how to separate the Master Cylinder from the booster. I sort of expected it to come apart with a gentle nudge once all undone but its stuck on there good and proper. Perhaps theres something else i have to undo.
Also when I turned the booster over a feral oily liquid poured out the Vacuum Line ... I thought that the Booster was a Sealed Dry Unit?!? Is there supposed to be something in there or has it been contaminated?
Bretski
Post Posted: Sat Aug 24, 2013 10:24 pm
Anyone?..
Post Posted: Sun Aug 25, 2013 2:07 pm
To the best of my knowledge, once you remove the two nuts, the master cylinder should just pull off the booster, and the booster is or should be a dry sealed unit.
Post Posted: Sun Aug 25, 2013 3:26 pm
As above....
Undo the retaining nuts and the master "should" just pull off the booster but corrosion on the studs will often hold it firm.
If you aren't in a hurry give it a good soak in wd40/crc/possum piss and try again later
OR
wiggle it harder.
Post Posted: Sun Aug 25, 2013 9:16 pm
Well I upgraded to a bigger hammer and gave it a bit more persuasion. It took more than a wiggle a wedge driven under the edge and finally I persuaded the master cylinder to part from the booster.
Still not sure why there was fluid of some feral description in the booster. I suspect that a previous owner had a major engine issue at some stage and managed to get fuel and water into the bacuum lines. I drained it and gave it a good clean up just waiting for the new master cylinder to arrive and time to reassemble.
Users browsing this forum: Google [Bot] and 303 guests
