http://auszookers.com/forum/
Time to get a snorkel. Way too close!!!
http://auszookers.com/forum/viewtopic.php?f=5&t=42599
Author:  luke3411 [ Thu Aug 22, 2013 10:26 pm ]
Post subject:  Time to get a snorkel. Way too close!!!
So after getting to the Daly river (yep the one with the massive swamp gecko's) at 2am in the morning, Me and my mate had to get to the other side where everyone else was meeting up with us. We had a look at the crossing but no way in Fk I was going to walk it. My mate drove across it a few times in his cruiser and we guaged the depth and what I was up against. So we finally took the plunge and even though the Vitara made it through without a hick up, I got to the other side and quickly flicked up my bonnet to check if everything was in it's place.
The air filter was saturated!!!!! I quickly flicked off the engine and then took the air filter apart and even though the filter was soaked there was no water in the bottom pan of the air filter assembly. I have a weber with the air filter that came with it so you have a rough idea what it looks like.
So after cleaning out my underpants I let the filter dry out, camped 2 nights and caught a few Barra then I got hold of a rope and got my mate to skull drag me back across with my air filter covered up where I proceeded to pull a troopy out of the sand :peaceout:
So these particular events have gotten my brain ticking over again as to getting a Snorkel.
So from Carby to Snorkel..
I would have to get a hat of some sort so that I could run that off the top of the Carby. Looked around and they all look pretty expensive. Anyone know of any cheap ones?
I want to get a filter set up that's either inline oooorrrrrr I would like more to get a filter box from another vehicle and set that up. Was thinking something bigger than a suzuki one to allow for a little more air flow. Hoping I can pick up the box from the wreckers.
Was just gonna buy a Snorkel off ebay for $200. Seems reasonable and has a cool little thing on the side saying Vitara.
Basically I would like to have this whole thing done and dusted for about $400 but less is always better. How have other people set theres up and what cost's did they incur?
Cheers Zookers!!
Author:  alien [ Fri Aug 23, 2013 3:42 pm ]
Post subject:  Re: Time to get a snorkel. Way to close!!!
i went through the same thing with my sierra and the weber i had on the 1.6 motor....
I took the expensive option and converted it to EFI, then ran a stock airbox and a regular snorkel =) lol
Author:  luke3411 [ Fri Aug 23, 2013 7:07 pm ]
Nah I like my little carby engine. Easy to fix.
I've been brain storming some more and was thinking if the weber carby's are the same unit but with different jetting, Would I be able to get a sierra air filter box and mount that in my vitara? Would it still allow enough air flow? and the such for this application? I know that people say that Webbers are no good with snorkels but plenty of people have done it.
Author:  Marko_SJ [ Fri Aug 23, 2013 7:21 pm ]
After reading some of the airbox tech on here it would seem sierra air boxes aren't the best.
Having said that, after reading some of the tech on here no part of a sierra is too good :?
Could you run a standard vit air box to a standard carby hat modded to fit like this:
viewtopic.php?f=5&t=41968&hilit=webber+install+how+to
Author:  alien [ Fri Aug 23, 2013 7:30 pm ]
http://www.redlineweber.com/html/applic ... norkle.htm
This is the proper solution to the weber snorkel... however its VERY tall - no way it fits under a sierra bonnet with a weber on top of a 1.6 with no bodylift... i don't think vitaras have all that much room to spare once a weber is bolted on either?
Author:  luke3411 [ Sat Aug 24, 2013 11:05 am ]
My Original hat died so havent got that any more to modify.
The air filter on the Carby I have sits fairly high already. I'll have a look at measurements to see if it will fit. or would a stock sierra carby hat that is moded do the trick? Hmmmm
Author:  damø [ Sat Aug 24, 2013 3:28 pm ]
Post subject:  Re: Time to get a snorkel. Way too close!!!
do you have that sports air filter thing as well? i made a shroud around mine to stop water splashing onto it before i binned it
Author:  Santos [ Sat Aug 24, 2013 3:36 pm ]
i have a spare sierra carb hat right angle adapter thingy f you want to mod it its gottom to go over the weber thrat which i'm guessing is square and not round like aisin/mkuni carbs?
Author:  atari4x4 [ Sat Aug 24, 2013 5:29 pm ]
tupperware airbox FTW
Author:  Sco-tie [ Sat Aug 24, 2013 5:33 pm ]
Sistema is the new tupperware! :rofl:
Author:  luke3411 [ Sun Aug 25, 2013 3:51 am ]
Yeah i got that sports air filter thing. I'm not a fan of it. Its just crumbled and is letting in stuff that scary looking. I found a few grains of sand sitting in the pan around the carb a few months ago. Engine has been fine though.
Author:  luke3411 [ Sun Aug 25, 2013 3:55 am ]
Santos PM sent
Author:  tassie jeeper [ Sun Aug 25, 2013 1:55 pm ]
i think u need to drive more steady in the water i on;y have a pod filter in mine and have drove through water up to my headlights without getting anything wet
Author:  luke3411 [ Sun Aug 25, 2013 10:40 pm ]
Yeah was going very steady. Was just above idol in first low. Was talking to a mate today and he said it might be my radiator fan spraying a bit of water around and soaking the air filter. I told him to shut up and stop killing my new excuse for getting a snorkel lol
Author:  Chop [ Sun Aug 25, 2013 10:56 pm ]
Tupperware lifetime warranty FTW!!! Armsup
Author:  tassie jeeper [ Sun Aug 25, 2013 11:32 pm ]
luke3411 wrote:
Yeah was going very steady. Was just above idol in first low. my radiator fan spraying a bit of water around and soaking the air filter.
id say thats probably your problem
Author:  atari4x4 [ Sun Aug 25, 2013 11:40 pm ]
i was kind of serious... something like this with the lid cut to suit the hole for the air filter & sandwiched between the carby & filter base plate, fit the filter & fit the base over the top, with either holes drilled on the firewall side for it to breath or somehow attach a snorkel to it.
Author:  Santos [ Mon Aug 26, 2013 12:03 am ]
atari you don't think it will warp with the heat off the engine and oven like conditions under the bonnet?
have had tupperwear sag when left near a hotplate
Author:  atari4x4 [ Mon Aug 26, 2013 12:26 am ]
:lol: probably, but i want someone to test my theory
Author:  luke3411 [ Mon Aug 26, 2013 8:57 am ]
I might give it a go for shits and giggles. I might hunt around for something a little thicker to try and prevent sag from heat.
Author:  Marko_SJ [ Mon Aug 26, 2013 12:18 pm ]
Microwave safe FTW? :thefinger:
Author:  tassie jeeper [ Mon Aug 26, 2013 12:54 pm ]
why not weld something up out of sheet steel will still be light if u make it thin enough, u will need to make it big enough so it can draw air from the space above the car when u smash the loud peddle
Author:  Santos [ Mon Aug 26, 2013 2:26 pm ]
Put it in an oven at 90 degrees celcius for an hour, then come back and tell us about your experience :thefinger:
Author:  Marko_SJ [ Mon Aug 26, 2013 3:20 pm ]
haha my food would now be sealed in plastic :lol: . My actual suggestion remains to find a stock one and mod to suit.
Although I am using a tupperware container as an airbox for my breathers and it is fine, I agree, use something else.
Author:  luke3411 [ Fri Aug 30, 2013 10:48 am ]
Ha ha. After. Few drinks last night me and a mate put the Tupperware theory to the test. It's working a treat. I'll try and post a few pics
Author:  atari4x4 [ Fri Aug 30, 2013 10:53 am ]
atari4x4 tupperware airbox®
Author:  Ausuki [ Fri Aug 30, 2013 4:49 pm ]
call it the iBox :P
Author:  damø [ Thu Sep 05, 2013 10:10 am ]
on the upside you could keep ham and cheese toasties warm while your driving around
Author:  atari4x4 [ Thu Sep 05, 2013 10:12 am ]
pics not loading :deadhorse:
