It is currently Wed Jul 29, 2026 9:28 pm
Vehicle: sj50 soft top
Post Posted: Sat Aug 24, 2013 6:14 pm
ok so i have an sj40 sierra, fitted with a nissan a15 and 4 speed, just had a g16a dropped into my shed, it will need a new carby and tappet cover, rebuild, alt, so on, but the box on the back isnt like the sierra box with the external transfer case, so what do i do? do i find a g13a 5 speed and put that back in with the 16a engine, or does the conversion have the full box from the 16a put into the sierra, does the g16a bolt onto a g31a box? that's the main question really, does the 13 box go on a 16, cos that would save time
Post Posted: Sat Aug 24, 2013 6:34 pm
Yes, it most definitely will go on. But, you will need the adaptor plate from BenT- viewtopic.php?f=15&t=15009
Vehicle: LJ50V, SJ70
Post Posted: Sat Aug 24, 2013 9:00 pm
The 1.3 gearbox will fit to the G16A with the BenT kit (which is a very well made kit, better than most out of the US), but don't forget to find a 1.3 flywheel and clutch as the G16A flywheel does not fit inside the 1.3 bellhousing. Some people choose to retain the Vit gearbox and make a rear adaptor to mate to the Sierra transfer/jackshaft. That way you can keep the G16A flywheel.
But another question you should consider is the size of your transmission tunnel. If your SJ40 is a Type 1 or 2, you will have to massage the sides to fit even the 1.3 box. If you have a Type 3, a 1.3 box will go straight in without any massaging. The Vit box will require major bodywork to fit the T1/T2, while a T3 will need a couple of thumps with a hammer.
A Type 3 jackshaft will also fit the output splines in a 1.3 or Vit gearbox, while the T1/2 jackshaft won't.
I was also going to mention engine mounts, but after your Nissan conversion, there probably won't be much left of your oriiginal mounts.
Which model SJ40 do you have?
Post Posted: Sun Aug 25, 2013 2:10 am
i dont know what one i have, i do know the vin so how can i tell?
Post Posted: Sun Aug 25, 2013 1:37 pm
If it's got a plastic dash you will be fine, depending on what they're done to fit the gearbox.
I'd just keep the A15. It makes the same power as a G16a and if it's already engineered that's a bonus. The biggest benefit would be the 5 speed.
You might be able to get a 5 speed for the A series (I believe they're pretty rare) but I don't know how much work it would be to fit. I looked at an LJ80 for sale with an A series and a 5 speed, they had to move the transfer case back to fit it, this resulted in a tailshaft about 30cm long flange to flange. I don't know if that was necessary, it was a dodgy clusterfuck of a vehicle so probably not. That gearbox certainly was very long though.
Post Posted: Sun Aug 25, 2013 3:07 pm
if i rebuild the g16a ive got a strong motor with plenty of after market parts, the 15a is so hard to get bits for and the 4 speed just means she screams her tits out to do 100km/h :/
Post Posted: Sun Aug 25, 2013 8:39 pm
rhys bond wrote:
i dont know what one i have, .....how can i tell?
Type 1 has metal dash and drum front brakes. (Approx '81-82)
Type 2 has metal dash, 4wd light on dash near Ign Switch, and front discs. (Approx '83-84)
Type 3 has plastic dash, 4wd light IN the instrument cluster and front discs. (Approx '84-87)
A 1.3 conversion will require front discs, a 1.6 conversion will require front discs AND a brake booster.
Post Posted: Sun Aug 25, 2013 8:53 pm
ok thanks heaps, i have the type 3, 87. break booster. hmm thats a new one too me, needing one of those,
Post Posted: Sun Aug 25, 2013 9:04 pm
Is the A15 already engineered?
Post Posted: Sun Aug 25, 2013 9:35 pm
i wouldnt say engineered but its in there and running true,
Users browsing this forum: Google [Bot] and 311 guests
