It is currently Sun Oct 04, 2026 4:31 pm
Post Posted: Tue Mar 10, 2009 9:06 pm
hi i have a 89 wt sierra but with a narrow track rear centre and rear half of the shaft.The unis a bit sloppy,and our local parts shop couldnt really be much help and had little idea.
i have one here part number:-KOYO RUJ 1783 it has 25mm OD cups and is external circlip and about 64mm across joint flat to flat.
both my nt and wt unis are eternal circlip and seem to be 25mm cup,are they the same?I havent pulled the other one out yet and would like to know first.thanks
lesspostingmorewheeling
Post Posted: Tue Mar 10, 2009 10:58 pm
as far as i know when i went to buy a uni joint NT and WT unis are the same
Post Posted: Wed Mar 11, 2009 12:18 am
RUJ1783 is 1.3 NT and WT with external clips.
1.0 use internal clips but otherwise same dimensions.
Sounds like you got a factory defect.
Jas.
Post Posted: Wed Mar 11, 2009 12:33 am
thanks fellas went to a mates and he helped me fit it.it worked fine but the dude at the shop told me the eternal clip was wrong and wouldnt work etc. i know now anyway cheers
Users browsing this forum: sideways and 195 guests
