It is currently Tue Oct 06, 2026 11:13 am
Vehicle: MY2019 Jimny
Post Posted: Fri Mar 13, 2009 5:07 pm
Well, is it 2 or 4 pin?
Post Posted: Fri Mar 13, 2009 5:14 pm
Gotta be 2.... but can't guarantee it :D
Post Posted: Fri Mar 13, 2009 5:17 pm
Thanks for almost helping!
Post Posted: Fri Mar 13, 2009 5:19 pm
You're welcome!! Any time I can almost be of assistance, just ask :lol:
Post Posted: Fri Mar 13, 2009 5:21 pm
I almost will.
Post Posted: Fri Mar 13, 2009 5:34 pm
i have a front diff center from a 85 drover and it is a 4 pin.
Post Posted: Fri Mar 13, 2009 5:39 pm
Thanks Shep.
Post Posted: Fri Mar 13, 2009 5:43 pm
ALL NT 3.9 centres are 4 pinion unless someone has played with it.
Jas.
Post Posted: Fri Mar 13, 2009 5:44 pm
Disregard what I said earlier :D
Post Posted: Fri Mar 13, 2009 8:01 pm
Jas.
Awesome, thanks.
Post Posted: Sat Mar 14, 2009 12:48 am
So the 1 litre diffs will fit a WT housing?
Post Posted: Sat Mar 14, 2009 12:59 am
no
Post Posted: Sat Mar 14, 2009 1:33 am
Damnit, I knew there was a catch...
Post Posted: Sat Mar 14, 2009 1:39 am
if they fit everyone would have 4.11's in their WT's
Post Posted: Sat Mar 14, 2009 1:43 am
Aren't they 3.9?
Post Posted: Sat Mar 14, 2009 11:52 am
One litre diffs are 4.11:1
1.3 NT diffs are 3.9:1
1.3 WT diffs are 3.7:1
Maruti 1.0 & 1.3 diffs are 4.10:1
Maruti diffs will fit into NT or WT housings.
Jas.
Post Posted: Sat Mar 14, 2009 5:46 pm
Jas.
Correction here. WT maruti diffs will fit into NT or WT housings :wink: . They have a NT flange though.
NT maruti diffs are 1L size so will not work in 1.3 diffs.
Member of C.O.R 4x4
Post Posted: Sat Mar 14, 2009 5:55 pm
Cool... :oops: Some useful tech popping up here. :wink:
Jas.
Post Posted: Mon Mar 16, 2009 1:47 am
when looking at an open centre how do you determine the how many pins it is?? what does pin actually stand for?
Post Posted: Mon Mar 16, 2009 1:52 am
A 2 pin carrier actually only has one pin or bar through it, wheras a 4 pin carrier has 3 pins - One long one and two short ones.
The long one is about 110mm long, and the shorties are about 45mm from memory.
4 pins are stronger for lockrights.
Post Posted: Mon Mar 16, 2009 1:56 am
so this would be a: Image ??
Post Posted: Mon Mar 16, 2009 2:03 am
4 pin - You are right, they are in good nick!
You can see two pins at 90 degrees to each other there...
Post Posted: Mon Mar 16, 2009 2:07 am
see i dont lie ;) that was straight out of the diff without touching it with a rag or anything.
Now i understand what the hell the 2 and 4 pin thing means ok thanks
Users browsing this forum: UBZ and 138 guests
