Vehicle: 03 grand vitara
Posted: Sat Oct 12, 2013 1:21 pm
Hi all First post, please be gentle I recently bought an 03 GV and bought a 50mm coil and strut spacer kit from O.S after a lot of modification and 6 hours i got the front in but the rear wouldnt fit at all. ( wrong kit) anyway my car is sitting un drivable and the minister of finance has given the ok to buy a suspension kit and tyres so my question is. Is there anyone in oz that sells a 3-4 inch kit that is any good?never carry much weight at all so the softer the better. thanx chris
Check out Outdoor auto, or dobinsons or lovells. each have their pros and cons. also have a read through other GV threads at what they have done and how they work. you can get a 2in coil lift and 1in spacers, any more than that and you start needing more mods and break things. And as its 03 you can't do a body lift. Why won't the spacers fit in the rear? that should be easiest. What did you have to mod for the front to fit? 50mm spacer in the front would be huge!
Users browsing this forum: No registered users and 439 guests
