http://auszookers.com/forum/
SJ80 revs issue
http://auszookers.com/forum/viewtopic.php?f=5&t=43392
Author:  Trebor [ Sat Oct 12, 2013 10:10 pm ]
Post subject:  SJ80 revs issue
I am having issues with my sierra, every time I try to accelerate weather it is from stand still or while already moving my revs drop hugly (if I want to get going I have to be atleast at 4000 revs or it will stall)
Anyone know what it might be??
Author:  SuziBlu [ Sun Oct 13, 2013 7:20 am ]
Post subject:  Re: SJ80 revs issue
Once underway how does it respond to the throttle.
How long since you done a service, ie looked at rotor cap leads and plugs, replaced.
Author:  ZukinLao [ Sun Oct 13, 2013 6:52 pm ]
I had similar sounding issue awhile back... cleaned out the fuel lines and replaced the fuel filter and no problems since.
Author:  Zook_Fan [ Mon Oct 14, 2013 8:55 am ]
Replied to you in this thread:
viewtopic.php?f=5&t=43312
Author:  Trebor [ Mon Oct 14, 2013 5:55 pm ]
ok so I get to the car to replace the fuel filter.......... Where is the fuel filter on the car???
Author:  Reubs [ Mon Oct 14, 2013 6:08 pm ]
Follow the fuel lines on inner side of the drivers side chassis rail to the rear wheel arch where you should see a filter bolted onto a bracket on the rail.
Author:  Trebor [ Tue Oct 15, 2013 11:38 am ]
Yeh I found it and the new fuel filter didn't fix it. I have a carburettor repair kit is there anything that I need to look out for when pull apart or and put I back together????
Author:  SuziBlu [ Tue Oct 15, 2013 11:45 am ]
doesnt sound like carby to me, sounds like the electrics, have you checked them.
Cap, rotor, leads and plugs ?
Author:  Trebor [ Tue Oct 15, 2013 12:39 pm ]
They are all in good condition and working
Author:  sideways [ Tue Oct 15, 2013 4:05 pm ]
So aside from that does it drive just fine? What are the other symptoms?
Author:  losfer [ Tue Oct 15, 2013 6:04 pm ]
unsure about sj80 but earlier sierra had a clutch pedal switch for emission control , if the switch played up displayed similar symptoms to yours , you disconnect the wires to the switch and jump them with a jumper wire and it fixed it.. worth a shot anyway if the sj80 does indeed have this switch.
Author:  coily96 [ Tue Oct 15, 2013 9:00 pm ]
Is it just revving low rpms or backfiring and shaking?
Author:  Trebor [ Thu Oct 17, 2013 12:31 am ]
Thanx guys for all the help it turns out that it was the fuel filter I just had to run it a little longer it has completely fixed now :-)
Just fitted some new tyres, I now have all terrains instead of almost bald road tyres
Author:  sideways [ Thu Oct 17, 2013 1:04 am ]
See you this weekend! Armsup
