It is currently Sun Jul 26, 2026 11:40 am
Vehicle: Suzuki Sierra 1996 SJ80
Post Posted: Sun Oct 13, 2013 6:23 pm
Will a 1988 model vitaras diffs fit a 1996 sierra?
Thanks
Post Posted: Sun Oct 13, 2013 6:26 pm
Do you mean the entire diffs? Then no.
The rear is completely different. The front 3rd member is similar, you can use the front R&P in a Sierra with some fiddling, they are a different ratio though.
Post Posted: Sun Oct 13, 2013 6:27 pm
what is the R & P
Post Posted: Sun Oct 13, 2013 6:33 pm
rack and pinion".
Post Posted: Sun Oct 13, 2013 6:35 pm
Ring and pinion.
Post Posted: Sun Oct 13, 2013 6:38 pm
whats that for?
and do any of you know if the transfer case will fit gearbox etc..
Post Posted: Sun Oct 13, 2013 6:41 pm
No the transfer doesnt fit. Its completely different.
Post Posted: Sun Oct 13, 2013 6:57 pm
will anything fit?
Post Posted: Sun Oct 13, 2013 7:44 pm
Not really. As has been said, the front ring and pinion gears. Nothing else of note will fit without modification or adaption.
Post Posted: Sun Oct 13, 2013 8:45 pm
might just grab the rims.
Post Posted: Sun Oct 13, 2013 8:54 pm
Nope, they are the wrong offset and will make your track width narrower.
Post Posted: Sun Oct 13, 2013 11:25 pm
if your sierra is still a 1.3 carby motor, the 1.6 carby motor in the vit will be ok to use... maybe...
Post Posted: Mon Oct 14, 2013 7:21 am
Except that it's eight years older, so unless it's been reconditioned (well) it's probably in much poorer condition than the 1.3 that's currently in the sierra.
If the donor car has power steering, you can pull that off and fit it to the sierra with a BenT adapter kit sold on here in the vendors area.
I've wrecked out quite a few vitaras. You'd be surprised how little can be swapped.
Post Posted: Mon Oct 14, 2013 7:50 am
well then, i wont be getting the rims, oh nah i will ill just put road tires on thm, would that be ok?
The engine looks like its been ruined, sandy and shit up in there.
ill have a look for power steering, and yeah steve i thought more stuff would be compatible.
Post Posted: Mon Oct 14, 2013 7:57 am
Oh, I just saw you have an SJ80, or coil sierra - 1996 was the changeover year, so it could have gone either way.
The rims have the same offset as an SJ80, so you can use the vitara rims on your car without a problem.
However, the front diff is completely different between an SJ80 and any other sierra, and a Vitara, so you can't use the front ring and pinion from a vitara in an SJ80. You could put the vitara front R&P in the rear of your SJ80, but you can't get a matching ratio for the front so it's pointless.
Post Posted: Mon Oct 14, 2013 10:04 am
The front wheel bearing r the same
but thats about it between the two cars
Post Posted: Mon Oct 14, 2013 10:52 am
Good point.
I thought I read the locking nuts on the vitara are superior.
Post Posted: Tue Oct 15, 2013 8:23 pm
yeah mate mines a coily
Users browsing this forum: No registered users and 12 guests
