| old man emu springs http://auszookers.com/forum/viewtopic.php?f=5&t=4410 |
| Author: | ajsr [ Tue Mar 24, 2009 11:14 pm ] |
| Post subject: | old man emu springs |
picked up some ome rear springs for my RUF today. can someone tell me is there a left and right side on these?? Im assuming not as they both carry the same part no's reason I ask is the rancho's they replace had left and right sides. cheers andrew |
| Author: | Bruce [ Tue Mar 24, 2009 11:17 pm ] |
| Post subject: | Re: old man emu springs |
Are they new ones? I usually put them side by side and the one that is taller goes on the drivers side. |
| Author: | ajsr [ Tue Mar 24, 2009 11:21 pm ] |
yep new I bought 4 new rears. I thought the same but they all sit identical. thanks bruce |
| Author: | ajsr [ Tue Mar 24, 2009 11:24 pm ] |
good looking springs though pulled the pack apart to get the main leaf out for spring hanger setup , the ome main leaf is 15mm longer than the rancho and has heaps better droop. |
| Author: | Chop [ Tue Mar 24, 2009 11:35 pm ] |
As far as i'm aware they stopped doing left and right springs. Chop |
| Author: | joeblow [ Tue Mar 24, 2009 11:36 pm ] |
ajsr wrote: good looking springs though pulled the pack apart to get the main leaf out for spring hanger setup , the ome main leaf is 15mm longer than the rancho and has heaps better droop.
longer............gee |
| Author: | Zook_Fan [ Tue Mar 24, 2009 11:38 pm ] |
how long have they been longer joe? and the rear springs dont have left and right sides it is only front springs that do that |
| Author: | jamienoble [ Wed Mar 25, 2009 3:52 am ] |
is ome definately the way to go for ruf? or would you reckomend efs or king spring?? i am chasing good flex and obviously a comfy rise. not so concerned about load carrying.. |
| Author: | Rockhopper [ Wed Mar 25, 2009 9:55 am ] |
efs and king springs are a much stiffer spring than the OME's, so yes, if you are going to do a ruf, get ome's. Make sure you do specify you want the softer rated springs, as they do make a heavy duty spring as well. |
| Author: | Gwagensteve [ Wed Mar 25, 2009 10:43 pm ] |
Rockhopper wrote: efs and king springs are a much stiffer spring than the OME's, so yes, if you are going to do a ruf, get ome's. Make sure you do specify you want the softer rated springs, as they do make a heavy duty spring as well.
I disagree. OME HD rears have a full length 2nd leaf that goes a LONG way to prevent springs bending. I've set up more RUF cars than I care to remember and I'd never recommend anything other than HD leaves. Cars with a light front end can run 3 leaves, heavy cars need 4 leaves. Steve. |
| Author: | ajsr [ Thu Mar 26, 2009 12:01 am ] |
Gwagensteve wrote: Rockhopper wrote: efs and king springs are a much stiffer spring than the OME's, so yes, if you are going to do a ruf, get ome's. Make sure you do specify you want the softer rated springs, as they do make a heavy duty spring as well. I disagree. OME HD rears have a full length 2nd leaf that goes a LONG way to prevent springs bending. I've set up more RUF cars than I care to remember and I'd never recommend anything other than HD leaves. Cars with a light front end can run 3 leaves, heavy cars need 4 leaves. Steve. steves right I rang ARB today to check and was told the difference is only the number of leafs in the pack not a leaf rate difference. |
| Author: | Rockhopper [ Thu Mar 26, 2009 12:18 am ] |
Well I stand corrected |
