Page 1 of 1
[ 9 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
coily96
Joined: Wed May 05, 2010 11:50 am Posts: 823 Location: Beenleigh
Vehicle: Coil Sierra
 Posted: Wed Dec 04, 2013 7:22 pm |
Have a high pitch noise from bellhousing, symtoms are
Noise more noticable at idle Noise changes with clutch pedal pressed in and out Not so loud with pedal out Very loud with pedal in Noise comes and goes
Had a stethiscope put over the engine bay and bellhousing has a dry bearing sound.
1.3 5 speed manual, clutch doesnt slip. New clutch kit two years ago. Car was in a mud hole for 10 mins last trip out.
When idle and clutch out you can also get rid of the noise my revving the engine, but ut comes straight back.
Thrust, throwout or imput bearing?
henno
Joined: Tue Jul 23, 2013 5:56 pm Posts: 2439 Location: Brisbane
Vehicle: Which one?
 Posted: Wed Dec 04, 2013 7:31 pm |
coily96 wrote: throwout Yep.
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5936 Location: Northcliffe, W.A.
 Posted: Wed Dec 04, 2013 7:34 pm |
henno wrote: coily96 wrote: throwout Yep. Yep.
MadMuz
Joined: Wed Nov 27, 2013 8:11 pm Posts: 30 Location: Landsborough, Sunshine Coast, Qld
Vehicle: Vit98 J20A SWB & Sierra89
 Posted: Wed Dec 04, 2013 10:20 pm |
+1 throwout bearing. If it were the input bearing shaft or spiggot bearing, pressing the clutch would probably make it better, not worse. If you have use of a borescope (camera) you can take a look at the bearing (without the engine running!) if you think it has got mud in there you can try flushing in thru the fork hole, but if it has been making noise for a while now, I would be changing it.... or at least get a new bearing and run the old one it til it starts sounding really bad. Trouble is it will prolly fail at the worst possible moment
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Thu Dec 05, 2013 3:55 pm |
Just as a trial, take the hose off the back of the tappet cover, see if that makes any difference, takes all of 1sec.
I had this, at idle, made a horrific noise, had the gearbox in and out 4 times, replaced everything, yet still a horrid squel like a dry bearing, but it wasn't.
The hose that ran from the back of the tappet cover, via the inlet manifold, to the air filter was at fault, and the idle vacum was causing a suction so great that the rear engine seal was sucking in air, damed if it didn't sound like a seized or dry bearing, thrust or spigot, out of the bellhousing she screamed.
So much drama, such a little tiny fix.
tanshi
Joined: Tue Jan 09, 2007 10:30 pm Posts: 7717 Location: Brisbane
 Posted: Thu Dec 05, 2013 4:06 pm |
SuziBlu wrote: Just as a trial, take the hose off the back of the tappet cover, see if that makes any difference, takes all of 1sec.
So much drama, such a little tiny fix. except it changed when you move the clutch in and out. throwout!
SuziBlu
 Posted: Thu Dec 05, 2013 4:23 pm |
As did mine.
That was what tricked me and the mechanic, foot on and off clutch, sound/pitch changed.
coily96
 Posted: Tue Dec 10, 2013 7:58 pm |
I was the throw out.
Caused buy the bellhousing bottom drain hole clogged with mud. Found a hand full of dirt in the bell housing and the same again in the clutch. All sorted now. Cheers
MadMuz
 Posted: Thu Jul 31, 2014 1:27 am |
Yeah, mines the same.... last owner must have been in deep and the rubber clutch fork condom was/is broken It is getting better actualy.... wont fix wot aint broke..... too busy
Page 1 of 1
[ 9 posts ] |
Users browsing this forum: No registered users and 234 guests
