It is currently Tue Oct 20, 2026 9:45 am
Vehicle: '92 Sierra
Post Posted: Wed Dec 11, 2013 11:14 am
I'm putting a G16a carb in a Sierra. I bought a mech fuel pump to suit only to find there is no provision on the head to fit it. I take it I'll have to go electric. What kind of pump will I need? Also do I just wire it via relay to come on when the ignition is on?
Vehicle: '92 Sierra
Post Posted: Wed Dec 11, 2013 12:00 pm
Ok so I realised this causes another problem. No mech pump means no pressure regulator or return line correct? To clarify this is a g13 carb on G16a engine which appears to be missing the mech pump mounting spot.
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Dec 11, 2013 3:41 pm
I thought both g13 and g16a heads both had the same provision ???
Vehicle: '92 Sierra
Post Posted: Wed Dec 11, 2013 5:39 pm
So did I but this one definitely doesn't. I've got the 1.3 and the 1.6 side by side and where the mounting spot should be on the 1.6 there is nothing. My main concern was the return line and reg that I thought was part of the mech pump. I've done some reading and apparently with a low pressure elec pump (facet) I don't need a return line. I'll give that a shot tomorrow.
Post Posted: Wed Dec 11, 2013 5:44 pm
There was a 8v Tbi g16 so maybe that is what you have. Can you put a pic up of the motor
Post Posted: Wed Dec 11, 2013 5:46 pm
M16a had 1
Vehicle: 1985 SJ51T
Post Posted: Wed Dec 11, 2013 6:18 pm
I swapped a swift motor (g13ba) into my sierra about six months ago. There was a blanking plate where the pump should have went. I removed 2 bolts and bolted my mech pump in. Not sure if that will help :)
Post Posted: Wed Dec 11, 2013 7:24 pm
shep is on the ball , the only 1.6 8 valve head that had no provision for the fuel pump was the spi model from the escudo. you can run a low pressure facet pump with no return
Vehicle: '92 Sierra
Post Posted: Wed Dec 11, 2013 8:33 pm
I considered the same thing re: TBI G16A but I didn't think they sold them in Aus. Well there's irony for you. I bought the engine with a weber on it and then sourced a TBI manifold from suzisport to run it on my other Sierra. Now I put it in this Sierra, switch it back to carby for RWC to find it was more than likely TBI all along. Since I ran the throttle body injector via an aftermarket ECU (Megasquirt) I'm still stuck having to change to carby though. I'll give the facet pump a go.
Post Posted: Wed Dec 11, 2013 8:45 pm
you bought that manifold from me when i worked there , lol .....
Post Posted: Wed Dec 11, 2013 8:49 pm
holy shit that was about 4 years ago or something ...
Post Posted: Thu Dec 12, 2013 7:39 am
Its an 89/90 Vit SPI manifold.
Users browsing this forum: Google Adsense [Bot] and 235 guests
