It is currently Thu Oct 01, 2026 11:08 pm
Vehicle: 2004 SQ625 GV
Post Posted: Fri Mar 27, 2009 1:08 am
I have got hold of a calmini winch guard/bumper and would like to mount the winch upside down to keep the grill free flowing. Has anyone seen or mounted a winch upside down if so were there any problems encountered.
Your replies would be helpful
Post Posted: Fri Mar 27, 2009 1:15 am
it will run backwards and the brake will stuff it all up
Post Posted: Fri Mar 27, 2009 1:22 am
I can't see any problems with mounting a winch upside down except you'll need longer cables for the solenoid box and a special bar to put it in, it certainly won't run backwards. :roll:
Airflow to the radiator really isn't a problem with a winch in front of it.
Jas.
Post Posted: Fri Mar 27, 2009 2:14 am
how can it even run backwards ?
Lj81.
Ke20.
Baleno.
Post Posted: Fri Mar 27, 2009 11:41 am
it will run backwards, my interpretation of mounting it upside down is the motor on the passenger side and the gearbox on the drivers side so you are flipping it, you flip something that spins it will turn backwards so before when you press winch in it will pull cable in the bottom of the drum now it will feed out off the bottom, you cant jsut run the winch the other way as the brake will fair get the shits with you
you could move the fairlead to the other side of the drum though if you are making up custom mounts for it all it wont be a problem
tjm run thier lowmount set ups this way, it just means the cable will spool from the top now and not the bottom. be sure to rotate the gearbox and or motor for propper clearances. oh....and are we talking about a low mount?
Post Posted: Fri Mar 27, 2009 12:33 pm
This the normal "upright" position for a lowmount where the cable spools off and winds onto the bottom of the drum.
Mounting it upside down, the cable will now spool off and wind onto the top of the drum.
Post Posted: Fri Mar 27, 2009 12:47 pm
hence the comment that it will run backwards, youll note 2 people said youll need to feed from the other side of the drum, so pulling from the top not the bottom, youll also note you arent one of those two people :wink:
Vehicle: 75 Cruiser
Post Posted: Fri Mar 27, 2009 3:54 pm
i think you're all confused :thefinger:
Post Posted: Fri Mar 27, 2009 4:54 pm
Righto :roll:
Vehicle: LJ20 LJ50
Post Posted: Fri Mar 27, 2009 10:23 pm
http://forum.difflock.com/viewtopic.php ... ad6faf8118
answered on another forum
Also the brakes may be a sprag brake (wiki e-description here)
http://en.wikipedia.org/wiki/Sprag
They only work one way by design
SO can you tell us what type of winch you will be using?
Camels have nice toes
Post Posted: Mon Mar 30, 2009 2:44 am
I am unsure at the moment i was just looking at mounting ideas. Does anyone one have any suggestions about a good brand of winches other than Warn?
Users browsing this forum: Google [Bot] and 175 guests
