It is currently Fri Oct 23, 2026 6:27 pm
Vehicle: 95 Suzuki Vitara V6 2.0L Auto
Post Posted: Sun Dec 22, 2013 4:38 pm
Hi guys,
I had one of my CV boots rip a little while back, so I decided to take out the CV and I fully degreased EVERYTHING on the CV, packed it with new grease that came with the brand new CV boots. After reassembling everything I get real bad clicking noises. I should mention, it WAS NOT clicking before cleaning the CVs (when there was a rip in the boot) even though there was a tonne of rocks and water in the joint itself. I should also mention that I have cleaned the CVs joints TWICE now, putting new grease on each time, the problem still persists.
Here is a video of the sounds I am getting: https://www.dropbox.com/s/j6akx3pe7zca5ey/IMG_0437.MOV
I know all signs point to 'buy new CVs' but I spent a fair bit in new boots and grease, and spent heaps of time cleaning them to perfection, yet they got worse?
I just want to know if new CVs will solve my problem completely, I don't want to spend $500 in CVs to find out its something else making the noise.
Cheers.
Post Posted: Sun Dec 22, 2013 5:08 pm
I've found clicky cvs are harder to break than quiet ones, I don't know why.
I would just order a new outer cv joint ($50 ebay) and keep it on the shelf to you break the clicky one.
Post Posted: Sun Dec 22, 2013 5:14 pm
Just watched the video. If its clicking in a straight line they're proper fucked. Just replace the outer cv.
also, be careful playing on the road in 4wd, it can bind up your transfer case.
Post Posted: Sun Dec 22, 2013 6:39 pm
Ahh, okay yeah, never thought of just buying the joint, ill probably replace ALL joints just to be safe. Although, one thing I should mention, I was never able to pull the outer CV joint off, I couldn't find any circlips any where and I wasn't game to hammer it off. How do I get the outer joint off?
Also, why would they start making the noise after cleaning? I really don't understand.
Edit: I forgot to mention, both the inner and outer boots were stuffed. For the inner joint I took everything apart and cleaned them out, but for the OUTER joint, since I couldn't get it a part, I just wiped excess grease off and then packed new grease in. Although the out joint didn't have any water of rocks in it, so I felt safe doing this.
Post Posted: Sun Dec 22, 2013 7:39 pm
The outers are held on by a 'snap ring' that sits in a groove on the spine. You cant see it without pulling it apart.
To remove it hit the star with a hammer, sometimes they come off easy but I've had to cut them off with a grinder before.
Usually the inners dont wear out/ break
Post Posted: Sun Dec 22, 2013 8:08 pm
I couldn't find any snap rings. I can't even see the spline because the race for the bearings is over it. Do you need to hammer the joint off? I can't find much on the net.
The inner CV was the main one that I wanted to clean out. It had the biggest tear in the boot, and it had a fair bit of water and dirt in it. It was also the only one I managed to take completely apart. The out CV had no dirt or water, so I just added new grease to the existing stuff. I have no idea how I could have gone wrong with reassembly, as there is really on 1 way for it all to go on. That's what makes me worry, what's going to be different with a new CV joint compared to a cleaned and re-greased one? There was no pits or dents in the bearings or race...
Users browsing this forum: No registered users and 59 guests
