It is currently Thu Oct 01, 2026 10:18 pm
Vehicle: 30s front locker barwork
Post Posted: Sun Mar 29, 2009 5:51 pm
my spottys stop working the other day n when i looked at the fuse the plastic cases around the fuse had melted wat could be a cause of this bcoz i dont want it happening again
Post Posted: Sun Mar 29, 2009 5:57 pm
too much current through too crap a fuse holder
ask VK Commondore owners about it :)
Vehicle: LJ20 LJ50
Post Posted: Sun Mar 29, 2009 10:40 pm
Get a circuit breaker from a GOOD auto parts place. Like this one on this page. Has a Fantastic flash player of what happens inside
http://www.bcae1.com/cirbrakr.htm
Cost about $20.00 and fits inline, self resets and you can use it later on something else.
Camels have nice toes
Post Posted: Sun Mar 29, 2009 11:02 pm
That's about the worst option he could take. I hate self resetting breakers with a passion.
The whole point of circuit protection is to cut power when there is a fault. The very last thing you want is the thing to reset and apply power again whilst there is a fault. The potential problem could possibly lead to an electrical fire.
Vehicle: LJ20 LJ50
Post Posted: Mon Mar 30, 2009 2:49 am
Then it will short out again. They are thermal so they don't just self reset in two seconds, they take time. There is also manaul reset versions.
With spotlights you get the poops when they keep cutting on and off then you fix it.
Post Posted: Mon Mar 30, 2009 10:43 am
And whilst you're merrily bopping along down the road it's still tripping out and resetting whilst you're blissfully unaware.
I know how they work, i also know how they cause bigger problems.
Manual reset is perfect it forces you to deal with the problem, auto is crap.
Post Posted: Mon Mar 30, 2009 11:01 am
check that ur wiring is corrct size etc also so u don't end up worse. auto resets are ok, they will also force u to fix the problem as they will be off more then on. if the original fuse holder was a good one there may be problems elsewhere.
[img]http://www.nbs4x4club.com/forum/files/thumbs/
Post Posted: Mon Mar 30, 2009 11:31 am
Look for corrosion on the terminals.
Corrosion causes high resistance, high resistance plus high current causes heat.
Users browsing this forum: No registered users and 166 guests
