It is currently Thu Jul 30, 2026 11:02 pm
Vehicle: 98 jimny
Post Posted: Fri Jan 10, 2014 2:44 pm
Dropped a new engine in my jimny after a water induced over heating issue
Now every time I try to crank it over it pops a fuse straight away,
Got the auto sparky out and he said the short is in this denso box
<a href="http://s136.photobucket.com/user/sam_516/media/Mobile%20Uploads/9079BDC5-481B-43AA-A931-30153FFCED61.jpg.html" target="_blank"><img src="http://i136.photobucket.com/albums/q162/sam_516/Mobile%20Uploads/9079BDC5-481B-43AA-A931-30153FFCED61.jpg" border="0" alt=" photo 9079BDC5-481B-43AA-A931-30153FFCED61.jpg"/></a>
He wasn't sure what it is for so befor I buy a new one and get him back out just want to be able to tell him what it is for
Post Posted: Fri Jan 10, 2014 2:54 pm
google says, HVAC Control Module
Post Posted: Fri Jan 10, 2014 2:55 pm
and before you ask, google says hvac means Heating, Ventilation and Air Conditioning
Vehicle: 98 jimny
Post Posted: Fri Jan 10, 2014 3:31 pm
So since It shouldn't be stopping the engine from starting then?
Vehicle: 98 jimny
Post Posted: Fri Jan 10, 2014 3:32 pm
Guessing that that is the burning smell I got ages ago last time I used the aircon
Post Posted: Fri Jan 10, 2014 3:59 pm
depends if the ecu looks to it for a signal for any thing.
Vehicle: 98 jimny
Post Posted: Fri Jan 10, 2014 4:30 pm
Just found a wiring diagram and the fuse that keeps blowin is the windscreen wipers...
I have no radio and no check engine light
The relays are clicking when I turn the key on and the starter motor clicks but won't actually crank, the battery is 100% full only just pulled it off the charger...
I'm lost
Post Posted: Fri Jan 10, 2014 4:33 pm
why are you lost. if the issue is in the hvac box get the hvac box fixed.
Vehicle: 98 jimny
Post Posted: Fri Jan 10, 2014 4:44 pm
If it burnt out when the a/c stopped working that was ages ago and was running with it blown, and it runs on a separate circuit to the ignition/radio
I'm going to replace the havc just to rule it out but I rang the auto electrition and he said it shouldn't stop it from turning over
Post Posted: Fri Jan 10, 2014 4:47 pm
I agree, but then if its not caused by the Hvac the auto elec should be able to tell you what is causing the issue
Post Posted: Sun Jan 12, 2014 6:34 am
Ahh mud! It kills everything. Did you try a new starter in it ?
Oh and I'd get a better sparky. :)
Vehicle: '94 suzuki maruti
Post Posted: Sun Jan 12, 2014 7:15 am
if the starter motor clicks but doesnt crank wouldnt that be an issue with the starter motor?
Post Posted: Wed Jan 15, 2014 2:34 pm
Try clutch starting it
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jan 15, 2014 2:55 pm
push starting?
have you tapped the starter yet? sometimes they get deadspots where they cant produce enough initial torque to get momentum and inertia required to start the car. giving it a tap with a hammer sometimes works.
extreme case is roll starting in 2nd, and trying to start the car at the same time you dump the clutch. ive seen this work just have to make sure you dont overrun the starter if it works for you
lowndsey did this one year in the v8's. lost his clutch so had to start the car in 1st and use the startermotor to drive the car forward till the engine kicked over, cos your tyres cant be spinning when you on the airjacks so he had to turn the car off while they were refueling and jacked.
Post Posted: Wed Jan 15, 2014 4:39 pm
Are the connections tight on pos and neg cables?
Users browsing this forum: No registered users and 387 guests
