It is currently Wed Sep 23, 2026 11:07 am
Post Posted: Wed May 27, 2009 11:50 pm
Can anyone tell me the differences between the G13A and G13B cranks?
Does the G13B (1324cc) have a longer stroke?
And will using a G13B crank in a G13A block with G13A pistons increase compression and if so by how much?
cheers B4T
Post Posted: Thu May 28, 2009 2:02 am
cheers B4T
Off the top of my head i'm pretty sure g13ba is 1324cc and g13b is 1298. The 1324cc does come from a longer stroke (75.5 vs 74 if I remember correctly).
b crank in a ba block will drop the compression going by that logic. NFI how much, would have to do the numbers.
Post Posted: Thu May 28, 2009 2:32 am
i thought i was confused before. i have used a G13B crank in a G13A motor
I have not used a G13BA at all.
stock G13B= 1298cc (has flat top pistons but short stroke)
stock G13A= 1324cc (has low comp pistons with longer stroke)
so i have a G13B motor that is now 1324cc in displacement. (due to longer strokecrank) So with this displacement and the flat top G13B pistons wont my compression have gone up over standard?
Last edited by Built4thrashing on Thu May 28, 2009 8:41 pm, edited 1 time in total.
Post Posted: Thu May 28, 2009 3:10 am
g13ba are coily motors and are 1298
lesspostingmorewheeling
Post Posted: Thu May 28, 2009 3:15 am
g13ba is a wt motor aswell
Post Posted: Thu May 28, 2009 3:25 am
G13A is the 'big block' 1324cc
Dan
Post Posted: Thu May 28, 2009 8:40 pm
ok so ive got the engines mixed up. but what ive done is still the same.
used the longer stroke crank in the smaller (1298cc) motor.
Ive edited last post to clear things up a bit
Post Posted: Fri May 29, 2009 1:46 am
found something ineresting on the net. details the differences between the G13a and G13b motors.
ironbark.bendigo.latro...f/lift.htm
What suzuki changed when they went from the 1324 to the 1298cc G13 motor.
Dated 25 , July , 1989
Change feature and identification:
Block assy:
From G13A to G13B
From 1324cc to 1298cc
Piston:
Note Type 'A' piston is concave , 'B' is flat top.
(center of pin to top.)
From 28.3 to 29.8mm
From 'A' piston ONLY to 'A' or 'B' for 9.0:1 CR or 9.5:1 CR.
Crank:
Center of crank to center of big end.
From 38.5mm to 37.76mm ( 1.486mm)
Camshaft:
Total max height of any lobe from back of lobe to tip:
From 38.148 to 38.136mm
Distributor assy:
Centrifugal and Vacuume advance char' are changed
Timing :
from 6+-1 Degree to 8+-1 Degree
For carburetor type.
From 1324 to 1298cc
From 77 to 75.5mm stroke.
From engine G13A to G13BA
From 8.9:1 to 9:1 or 9.5:1 CR
From 10^ BTC to 6^ for 9.0:1 CR and 8^ for 9.5:1 ( all at 850 RPM)
Heres an interesting one.
Cooling solution from 5.0 L to 4.8 L
Post Posted: Fri May 29, 2009 2:26 am
I would trust Jeff's info over my dodgy memory any day of the week!!!
Post Posted: Sun May 31, 2009 4:56 pm
everything is up and going but what timing should i set?
The 1324cc is normally set at 10*TDC but ive read somewhere that the 1298cc is only set at 6*TDC. so what should i run? Having the flat top pistons and a slightly higher compression im thinking it should be about 6*TDC
what you think
oh and it pings a bit at 10* with 91octane unleadded
Post Posted: Sun May 31, 2009 6:15 pm
what you think
Yeah start with 6 and go from there.
Post Posted: Sun May 31, 2009 6:32 pm
i thought the 1298 was supposed to be set at 8btdc
Post Posted: Sun May 31, 2009 8:22 pm
wind it up till it pings then back it off some :)
Post Posted: Sun May 31, 2009 9:31 pm
took it for a rive yesterday and it feels weird as it now has a clutch fan
Makes heaps of noise . need to get some kms under the tyres so i can send it off to be dyno tuned. carby needs a reco anyway.
timing is set at 6* and is alot better and only pings under heavy accel. alot better than the 10*it was origanially set at.
will keep ya updated as i go. B4T
Post Posted: Sun May 31, 2009 10:34 pm
Just run better fuel in it, 91 is crap!!!
Users browsing this forum: No registered users and 139 guests
