It is currently Tue Oct 27, 2026 11:44 am
Vehicle: 1.6 Vitara jlx
Post Posted: Mon Mar 31, 2014 7:55 pm
Hey guys
I have a 95 LWB Vitara and am torn between both lift and tyre choice.
I was originally considering a 2" lift and 30x9.5 tyres, but everyone seems to run atleast a 3" lift with these tyres.
Is there anyone out there running 30s with a 2" lift and no issues or are 235s the limit.
I am not interested in a body lift, just suspension lift.
Post Posted: Tue Apr 01, 2014 10:30 pm
Can be done with 2", you might need to changed ur bumpstops (screw in extensions avail) How big they are depends on what rims you use.
Vehicle: SJ80, SE416
Post Posted: Tue Apr 01, 2014 11:24 pm
To properly clear 235/75r15 on an SE series Vit you will need bump stop spacing and adjustment of the steering stops as a minimum. Lift alone will not do the job.
Post Posted: Wed Apr 02, 2014 4:20 am
I have 235's on mine with none of the above ^
Post Posted: Wed Apr 02, 2014 12:14 pm
I have 31 with bumpstop spacing
Vehicle: 1996 Vitara LWB
Post Posted: Wed Apr 02, 2014 3:58 pm
Im running 235/75/15 M/T's with no spacers or suspension changes. I haven't been off road yet, but I do get rubbing on full lock (only) in reverse. I would go with the 2" lift minimum, and the spacer would make a difference off road for sure.
Vehicle: sj51
Post Posted: Wed Apr 02, 2014 4:06 pm
i think the question here should be... how much bumpstop do i need to add to run "X" size tyres and will i need to trim anything
spring lift alone wont stop tyres rubbing... when the suspension cycles it will still move through the standard range and stil rub...
you want to use bumpstops and triming to eliminate rubbing, then figure out how much up travel you want and order springs and shocks to suit
Post Posted: Thu Apr 03, 2014 9:13 am
40 mm bs spacer will clear the back of a lwb with short shocks around 500ish
With 640 long shocks I needed 70mm
Users browsing this forum: Google [Bot] and 264 guests
