It is currently Sun Oct 04, 2026 10:31 pm
Vehicle: Suzuki Sierra 1996 SJ80
Post Posted: Wed Jan 22, 2014 1:59 pm
30mm coil spacers and 30-40mm suspension kit off ebay. thoughts? will the car still drive alright? will i need castor bushes?
all advice appreciated
Post Posted: Wed Jan 22, 2014 2:01 pm
No. Yes.
Stacking kits does not make for a better coil sierra. Their suspension design is almost lift allergic if you can't fabricate. I'd leave it as one or the other.
Post Posted: Wed Jan 22, 2014 2:47 pm
ahhhhh but i want more then 1 34/86"of lift
Post Posted: Wed Jan 22, 2014 2:52 pm
why do you need more lift?
Post Posted: Wed Jan 22, 2014 2:59 pm
i probably dont but it would be good
Post Posted: Wed Jan 22, 2014 3:30 pm
I had 31 and 30mm lift and never needed any more because of the short wb
The almost 100in vit on the other hand needs all the lift I can get
Post Posted: Wed Jan 22, 2014 4:45 pm
Bozy97 wrote:
i probably don't but it would be good…
for driving around with the front shocks topped out
for adding caster correction bushes so the axle brackets break off
for adding no travel or flex
for exacerbating the hugely mismatched front the rear roll stiffness.
If you want the lift for running bigger tyres, you don't. Put the bigger tyres on and work out whether to cut guards, run a body lift, space the bumpstops or all three. Adding suspension lift to a coily doesn't make them better.
Post Posted: Wed Jan 22, 2014 9:23 pm
More lift doesnt equal more capable.
Check out some rigs on here and you'll see low is the new lift
Users browsing this forum: No registered users and 196 guests
