i am looking to buy a baleno 1.6 g16b questions i need answered are \ 1 can I buy the automatic baleno will the fly wheel bolt up if i buy an auto balena ??????????? 2 i know i need a coil pack model what years where they made and look like photos would be help full 3 been told i need to get a swift water houseing 4 and modify sump 5 have allready bought ben t kit
1. the end of any g series crankshaft is the same so any baleno motor will be fine . 2 . the best one is the one that uses a cam and crank position sensor , if you cant see a distributor then its good. 3. yeah you need the hose pointing the right way , not into the firewall , which is where it points with the baleno housing . 4. you will need to modify the sump and pickup , not something you can do at home with little skill and no welder. 5. whats the question here ?
re question 5 is that all i will need and sump does any one have photos of what needs to be done and the coil pack engine easy to see cause there are coil packs on top of rocker cover ???and no dizzy
The coil packs are in a couple of different spots depending on the model/version of the engine.... but none of them have a dizzy, which is why it was easier for losfer to just say "if you cant see a distributor then its good".
Users browsing this forum: Google Adsense [Bot] and 148 guests
