http://auszookers.com/forum/
F10a Start up trouble
http://auszookers.com/forum/viewtopic.php?f=5&t=45257
Author:  dickothesicko [ Tue Feb 25, 2014 9:37 pm ]
Post subject:  F10a Start up trouble
hi all I just bought a sierra ute ( first Suzuki by the way ) for a shooting bus and I am having trouble getting it running, I think it was built in 83, its a sj40t with a f10a, now I drained the fuel tank and put new fuel in, I put a new fuel filter and replaced the inlet and outlet hose off the fuel pump as they were cracked, I checked the pump and its working, I gave the spark plugs a quick clean, the car will start and idle but will only run for around three seconds before it shuts off and if you touch the throttle it dies, it will rev higher when the choke on when you hit the key but wont run as long, I pulled the carby off and all it says is aisan, i have never touched carbys before but it would need a kit through it.
any help would be greatly appreciated, cheers kyle
Author:  jamiec [ Wed Feb 26, 2014 10:30 pm ]
Post subject:  Re: F10a Start up trouble
Have you checked the fuel float level on the carb?
Author:  dickothesicko [ Thu Feb 27, 2014 2:59 pm ]
Is there a mesurment for where it should be sitting? It did have plenty off fuel in bowl though, roughly three quarters to the top. I still don't know how to tell what model carberetor it is.
Author:  dickothesicko [ Fri Feb 28, 2014 5:22 pm ]
I've never played with carby's before but it did have plenty off fuel in the bowl, the thing that has me stuffed is it just shuts off not actually on off then dies like a normal engine starving for fuel.
Author:  mmiller6512 [ Fri Feb 28, 2014 5:42 pm ]
Check the strainer under the needle and seat.
Mine was very dirty and was doing the same thing.
Author:  MadMuz [ Fri Feb 28, 2014 5:58 pm ]
Make sure if it has a fuel cut off solenoid on the carby, that it is working properly. I had an 87 barina that wouldnt idle, but would run if the throttle was slightly open, turned out to be a micro switch under the throttle pedal that was supposed to tell the solenoid on the carby to stay open to idle. The solenoid stopped the fuel flow on back off, over run. Just thinking yours is of similar age and might have similar problem?
check any wires connected to carby are clean and making good contact, check fuses and any earhs under bonnet are good.Check points, leads and clean under dizzy cap... look for cracks in cap.
Author:  dickothesicko [ Fri Feb 28, 2014 6:08 pm ]
Yeah thanks guys I will go have a look on the weekend at some stage, I would still like to know what model carby it is if anyone knows? And also will the f8a head fit the f10a block?
Author:  2stroker [ Thu Mar 06, 2014 7:55 pm ]
Yep that is usually the problem associated with the described symptoms.
Author:  dickothesicko [ Thu Mar 06, 2014 8:14 pm ]
Yeah guys I cleaned it all out tonight and now it runs like a champ, cheers for help,
Author:  sideways [ Thu Mar 06, 2014 8:24 pm ]
F8a head fits. It's practically identical aside from the oil seal housing on the front. You'l need to use the F8a rear timing belt cover too.
Author:  dickothesicko [ Thu Mar 06, 2014 8:40 pm ]
Yeah it has one on it, I was just double checking it's possible.
Author:  MadMuz [ Thu Jul 31, 2014 1:02 am ]
Old fuel? It goes off quick these days .... short 'shelf life' so to speak
