| Wiper problem http://auszookers.com/forum/viewtopic.php?f=5&t=4526 |
| Author: | jamhic [ Tue Apr 07, 2009 3:28 am ] |
| Post subject: | Wiper problem |
Hi All, just bought a 1990 model zook. Will be going for a road worth in the next week or so and need to sort out a problem with the wipers. When I turn the wipers on they work fine at all different speeds, but will not turn off until you turn them to the off position and turn the key off as well. Any ideas? |
| Author: | Saam [ Tue Apr 07, 2009 3:31 am ] |
| Post subject: | Re: Wiper problem |
stuffed switch ? |
| Author: | jamhic [ Tue Apr 07, 2009 3:41 am ] |
that is my initial thought. I am going to have a play with it tomorrow. Let you know how I go |
| Author: | Rockhopper [ Tue Apr 07, 2009 9:58 am ] |
| Author: | royce [ Tue Apr 07, 2009 11:16 am ] |
sounds like the self park bit in the control box thingy is stuffed |
| Author: | Hybrid [ Tue Apr 07, 2009 12:29 pm ] |
I started out with the same problem. Then it would also trigger the windscreen washer pump off the indicator relay thingy (on-off-on-off). Now its pregressed to any time I indicate left the wipers come on and the pump runs off the flasher unit. I think its the internals of the column control unit breaking down. My suggestion would be to nab a new one from the wreckers. |
| Author: | oscar [ Tue Apr 07, 2009 12:46 pm ] |
check the earth to ur window surround |
| Author: | jamhic [ Tue Apr 07, 2009 8:30 pm ] |
Hey guys! Thanks for the thoughts. Had a play with it today and the previous owner had disconnected the pump for the squirters which was causing the wipers not to turn off. The pump had been disconnected due to the valve in the line between squirters and pump was blocked. But all fixed now so thanks again for all your ideas. Regards James |
| Author: | Rockhopper [ Tue Apr 07, 2009 9:22 pm ] |
Ok. Now I'm confused. Why would the windscreen washer pump affect the wipers switching on or off?? Unless the wiper motor somehow earths through the washer pump (but I doubt it) |
| Author: | Zook_Fan [ Tue Apr 07, 2009 9:40 pm ] |
wiper motor earths straight into the windscreen sorround. |
| Author: | jamhic [ Tue Apr 07, 2009 11:16 pm ] |
well as strange as it sounds thats exactly what happened! Would be really interested to know if it is just my car. To test just pull the wire off the squirter pump and then try turning your wipers on and off. Oh well i'm happy mine is working fine. |
| Author: | royce [ Tue Apr 07, 2009 11:59 pm ] |
I would say a fault somewhere is making it earth through the washer power line into the pump |
| Author: | lump_a_charcoal [ Wed Apr 08, 2009 1:18 am ] |
OK, how about this one? My wipers work fine, except for Int. WOuld that indicate a dodgy switch, motor or anything else? |
| Author: | Rockhopper [ Wed Apr 08, 2009 1:24 am ] |
what does it do on int?? If it does'nt work at all, I'd suspect the switch |
| Author: | lump_a_charcoal [ Wed Apr 08, 2009 1:28 am ] |
yeah it does SFA when on Int... |
