It is currently Mon Sep 28, 2026 10:41 pm
Post Posted: Wed Apr 08, 2009 11:48 pm
This is probably a dumb question, but what would be the impact on drivability of a 1999 V6 Grand Vitara if I removed the sway bar?
Post Posted: Wed Apr 08, 2009 11:50 pm
NO diff at all, I had mine removed for well over 3 years without a worry in the world.
Post Posted: Thu Apr 09, 2009 12:15 am
Hi Bruce,
What are the pros and cons of removing the sawybar?
Cheer
99 Grand Vitara
More work to come
Post Posted: Thu Apr 09, 2009 10:20 am
You get more flex out of the front (ya need it with IFS)
It will get just that little bit more body roll going around corners but driving normal you won't notice it.
Take it off (if you want) drive it NORMAL and see mate. I bet you won't put it back on.
Post Posted: Wed Apr 15, 2009 8:40 pm
I removed mine about 6 months ago. There's a fraction more body roll and do notice more spring movement noises. I think the spring moves around when going through ditches, down curbs etc and makes a slight grinding sound.
I'm going to put it back in for legaility reasons though.
2002 SWB GV
Lifted and Locked
Post Posted: Thu Apr 16, 2009 5:05 pm
I removed mine to see what its like - makes a big difference in the front end as Bruce said - but I didn't like the feel on the road - figured its only 6 bolts to drop it anyway when required....
With the bar on - it couldn't flex far enough to drive up on the ramps like this, without - no problems.....
Vehicle: Sold zuk got a Bt50
Post Posted: Thu Apr 16, 2009 8:01 pm
And an even bigger Dumb question were is the sway bar i am 99% sure i know were it is but just want to make sure it is b4 i go pulling it off just incase it is something else important
pictures would be awesome
and ZX1990 noticed you had manual fount diff locks how much they set you back and were did you get them done ??
have you done anything to the rear ??
Post Posted: Mon Apr 20, 2009 5:47 pm
Its the long bar - with 2 90 degree bends either end - its held onto the body by 2 D shaped brackets, and to the lower arms by 2 link rods.
I fitted the manual hubs myself - cost me $120 from a wrecker, I just cleaned and regreased them - they bolt straight on - very easy job....
Rear has 30mm coil spacers from Bruce and Dobinsons shocks - also 30mm longer.
Users browsing this forum: No registered users and 166 guests
