It is currently Sun Sep 27, 2026 10:21 pm
lesspostingmorewheeling
Post Posted: Fri Apr 10, 2009 9:42 pm
how do you remove windscreens and back windows without breaking them?
cheers
mike
Post Posted: Fri Apr 10, 2009 10:38 pm
I usually lay a nice thick blanket on the bonnet and then sit between the seats with my feet in the top corners of the screen and push evenly with both feet.
After you've done a few like this you can remove a screen in 30 seconds or less.
This only works for screens with NO cracks. If screen has a crack you WILL have to replace it. Chips may or may not be a problem.
Jas.
Post Posted: Fri Apr 10, 2009 10:47 pm
I have seen a few people roll it and it popped the screen without damaging it, perhaps give that a try :)
Post Posted: Fri Apr 10, 2009 10:49 pm
+1 on pushing it out with your feet. Works pretty well actually.
However if it's the glued in type you have to cut it out (wire is the easiest, although you can use the pneumatic cutting tool thing.. personally I think the cheese wire is easier.)
Post Posted: Sat Apr 11, 2009 1:33 am
i use about three or four screwdrivers and start on a corner the carefully peel the window out no worries it may take a while but you get there
Users browsing this forum: No registered users and 100 guests
